Previous in Forum: Two Schools of Thought on Space Exploration   Next in Forum: Mars - There's Quite a Lot of Water There
11 comments
Repairing copper pipe
09/26/2013 5:06 PM
Does anyone know about welding copper pipe? I have a piece of copper 1" tubing/pipe that has a freeze split in it. It is a coil that is about 18" in diameter and stands about 2'. Whoever made this up, did it with several pieces, and the welds appear to be copper. Looks more like acetylene welding. Fill me in on the procedure. Thanks
Pathfinder Tags: repairing copper pipe
Re: Repairing copper pipe
09/26/2013 5:44 PM
09/26/2013 6:48 PM
most likely its solder, perhaps silver solder if it was a high pressure application. you need to cut the split out and solder in the same size pipe with copper couplings, you can find most of that stuff at a home center like Home depot or a better hardware store
09/26/2013 7:22 PM
If you are not experienced with this type of high temperature soldering, there is mechanical connection method.....video instruction for this repair....start at 1 min...
https://www.youtube.com/watch?v=UE9WbTFLnTI
SharkBite fittings....
Good Answers: 104
09/26/2013 7:39 PM
You don't say what medium is outside and inside the pipe and the pressures involved. The problem with trying to cut out a section and use couplings to install a new piece is this - since copper is very malleable a considerable length may have been 'hydraulically' expanded beyond the section that split. If so, a coupling will not fit over the pipe. If this is moderate pressure water inside with a low pressure medium on the outside, you might try cleaning the sides (edges) of the split, then squeeze the pipe/tube back together and solder or braze the crack back together. (Or solder/braze a 'band-aid' over the split.)
09/26/2013 8:27 PM
reminds me of a couple of drain lines in 15 degree freezers I've repaired
09/27/2013 3:12 AM
It is more likely to be silver-solder, or brazing, although regular solder will provide excellent service at temperatures up to, oh, say 135degC, so it depends upon the wetting materials each side of the coil and their temperatures and pressures, which haven't been mentioned in the original posting.
The best repair is to chop out the affected section for scrap, and renew it.
09/27/2013 10:43 AM
You dont weld Cu pipe, you braze it.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
10/01/2013 12:31 AM
In reality,copper pipe can be soldered,brazed, or welded.
Soldering occurs at below around 840F.
Above 840F is considered brazing.
And of course, welding is accomplished at the melting point of the particular alloy of copper,which is around 1981F for copper.
09/27/2013 3:52 PM
Yes copper pipe can be welded with the tig process and a footpetal to control heat, however it is not practical for a repair job.
09/28/2013 10:37 PM
Thanks for all the comments. What I found out was that a hand held wire brush was not enough and after using an electric wire brush, the weld was definitely done with brass. Look first and then speak, aye.
10/01/2013 12:19 AM
Solar Eagle hit the nail on the head. The Sharkbite fittings are the easiest way for a non-welder type person to do the job. I have used them,and They do not leak, and are very simple to install.
Cut the pipe, debur it, and press the fitting on.You will need a short nipple of the same type as the leaking pipe, and 2 fittings,unless the split is very short. That's it.
I know how to sweat and\or silver solder copper, but for household water supply,I will never solder again.
The higher temperature (and price) silver solder I will reserve for A/C units and high pressure systems.
Good luck.
A GA to Solar Eagle!
Register to Reply 11 comments
bigg (1); Fredski (2); HiTekRedNek (2); lyn (1); pipeit (1); PWSlack (1); ronclarke (1); SolarEagle (1); tatonkapark (1)
