Previous in Forum: Installing Piping System in Concrete Trenches   Next in Forum: Pressure Vessels
Flange Material
09/26/2013 8:30 PM
To all,
Anybody has an idea on how to flange leak check flanges whose material
is A694-F65. I cannot find it in B16.5 Table 1-A. BTW i am using CAESAR II 5.31.
Kindly advise me on how to handle with this.
Thanks a lot.
Re: Flange Material
09/27/2013 2:16 AM
Guys,
I found already solution for this.
Just ignore this post anyway.
<<chaddix>>
Re: Flange Material
09/27/2013 3:19 AM
Hydraulic test, then pneumatic test to a lower pressure, using washing up liquid solution to see where the bubbles are coming from?
The second part is a similar technique to testing a bicycle inner tube before applying a patch.
Re: Flange Material
09/29/2013 11:26 PM
PWSlack,
Thanks for the info.
I already have the solution for this one. This is a Flange Leak Check method
of CAESAR-II using Pressure Equivalent Method in which file look-up doesn't
have the material I have mentioned above.
Anyway, thanks for the reply.
<<chaddix>>
Register to Reply 3 comments
