Previous in Forum: Android Nightmare   Next in Forum: And the Cloud Goes Poof...
How to Unhide Hidden Files of USB HDD?
09/27/2013 11:39 AM
Dear Sir,
I am using WD 250Gb USB Portable HDD. I am facing problem with hidden folders/Files please check details,
Step 1, I created new folder in my USB HDD directory.
Step 2, I copied Some videos files in new folder of HDD
Step 3, I right click on new folder & select Hidden Tab after that folder quickly hidden.
Now i want to un hide that folder but it vain :(
I tried to go windows folder option & select ' Show Hidden Files & Folder' but there is no any new folder appeared but memory usage still showing my videos files are here. please solve my problem. please note that i have enabled password option of this drive.
Always Respect Your Seniors. Best Regards, Ahmad Arshad
Re: How to Unhide Hidden Files of USB HDD?
09/27/2013 1:27 PM
Disable password and try again. If folder options are set to show hidden folders, when you put cursor over hidden folder it will still show memory usage there. If you do not see contents but device shows memory used, then you need a recovery program.
09/27/2013 3:33 PM
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
09/27/2013 6:15 PM
Get Total Commander [use to be Windows Commander till bill sent him a "letter" a decade ago] free and no adware. It's shareware that doesn't go away just gives a "send http://www.ghisler.com/ $ and avoid this screen" when you first start it. All the old commands from the Blue screen DOS masterpiece Peter Norton wrote 30 years ago. Trust me, and set it up to show hidden files, you'll never use WE again unless you have to, it's on all my USB's.
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Register to Reply 3 comments
kwcharlie (1); LongintheTooth (1); SolarEagle (1)
