Previous in Forum: Electrical Motor   Next in Forum: Pyroblocks
Carbon to SS Welding
09/28/2013 9:13 AM
At one of my site for SS304 pipe, we have welded IS2062 pipe supports. Now to avoide contamination during operation what we should do.
The liquid handled by piping is DM water, and IS2062 is not going to come in contact with liquid.
Plant is not chemical or any hazardeous.
Re: CARBON TO SS WELDING
09/28/2013 10:11 AM
Don't do anything. You can passivate the weld, or brush it with a SS wire brush and coat the weld with something to keep it dry.
You may get some localized rust but it will be on the outside of the pipe.
Good Answers: 203
Re: Carbon to SS Welding
09/30/2013 12:14 AM
Anonymous Poster #1-
Hope you used SS rod to weld the steel pipe supports to the SS pipe! Best to use SS rod and not steel rods for welding of SS to steel. Except in a few cases always the rods of the better metal to weld dissimilar metals. This also holds true for different grades of SS. For 304 and 316 use 316, etc. Even better to TIG weld it with the appropriate wire/rod grade and size.
Wire brush or grind the surfaces to be welded to get them as clean as possible. Then weld. Chip any slag off if rods were used, no chipping if TIG was used. Wire brush all joints to remove any residuals. Paint with a suitable paint for the metals and the atmosphere.
Good Luck, Old Salt
