Previous in Forum: Wood Gas Generator   Next in Forum: Carbon to SS Welding
Electrical Motor
09/27/2013 3:11 PM
In Double speed pole changed 37kw motor take how many current.For installing MPCB what is the rating of this.
Re: Electrical motor
09/27/2013 3:33 PM
This would be the responsibility of the electrical contractor performing the task.
Some real information will be needed by whomever does the work.
The MPCB's would need to be large enough to protect the wiring.
09/27/2013 4:16 PM
Read the label on the motor. It will tell you what voltage(s) should be applied and the running current it will draw. You should expect that the current will be higher when starting. The start current will briefly be the locked rotor current rating. There's a lot of information and code referencing that should be done when properly installing a motor, the associated wiring and protection circuitry. Let a professional handle this.
09/28/2013 2:47 PM
WHAT VOLTAGE? (Yes, I am deliberately shouting.)
09/28/2013 3:34 PM
  1. Locate a copy of British Standard 7671.
  2. Open at page 1.
  3. Read on.
Register to Reply 4 comments
lyn (1); PWSlack (1); redfred (1); Tornado (1)
