Previous in Forum: Earthing Strip   Next in Forum: Minimum Insulation Resistance
Over Current & Earth Fault Relay
09/29/2013 3:11 AM
In low voltage system, if there is already over current and earth fault relay in main switchboard, is it still necessity to provide the same at the downstream sub board ? What is the minimum requirement in using over current and earth fault relay ?
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Re: over current & earth fault relay
09/29/2013 6:48 AM
what is the voltage and current involved, and under which code are u working?
BSEE but always learning
09/29/2013 9:12 AM
09/29/2013 10:08 AM
Electrical wiring codes are different from country to country. They also change depending on the type of location within that country. Consult your regional code standards. CR4 is not the provider of your code standards.
Re: Over Current & Earth Fault Relay
09/30/2013 4:33 AM
...nor does it provide training with those standards and certification of competence.
Good Answers: 170
09/30/2013 10:51 AM
Yes, if you want proper co-ordination
Good Answers: 34
09/30/2013 1:28 PM
The O/C and E/F relay in Main Board is provided
1. To suit rating of the switch board
2. Protect Distribution transformer or Feeder from Over load.
3. Protect cables from Transformer secondary to the Board or Feeder cable.
The O/C and E/F relay for down stream feeders is provided:
1. To protect cables supplying that feeder.
2. To ensure power to remaining loads connected to same Board is not disrupted for fault on a particular downstream feeder or consumer.
3. The probability of phase to earth fault is always higher than phase to phase fault - hence a properly set E/F relay will
3.1 Provide desired discrimination.
3.2 Avoid subjecting downstream cables and equipment to longer duration of fault.
So depending upon ratings (where HRC fuse is not feasible). it is preferred that all downstream feeders have suitable O/C and E/F protection.
Register to Reply 6 comments
1capybara (1); electricalexpert65 (1); lyn (1); powersolutionsFBD (1); PWSlack (1); redfred (1)
