Previous in Forum: Simple Motor Control Application?   Next in Forum: Inconel Axles
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Taking Control of Noise
06/05/2007 1:19 PM
Balancing energy needs with environmental restrictions is a constant challenge. A major gas processing plant under construction in Nyhamna, Norway needed innovative control-valve technology to meet rigorous noise requirements. The plant, which will consist of several seabed installations at depths between 800 and 1100 m, will use control valves with low noise trims to helps meet the sound regulations. These trims merge several noise abatement methods including a distinctive passage shape, multistage pressure reduction, exit jet separation, and an expansion area; all calculated to diminish the acoustic energy radiated in the audible range. Some of the valves will have special actuator systems for quick operation. [To access this article a short registration may be required.]
For more on this subject, subscribe to GlobalSpec's e-Newsletter, DIRECTU2 The world of Shock, Vibration & Noise.
The preceding article is a "sneak peek" from Valve Technology, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Valve Technology today.
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
Re: Taking Control of Noise
06/07/2007 6:28 AM
That's great Moose, I'm now on the whole noise reduction thing again!
'The truth is out there' The lies are in your head.
06/07/2007 11:27 AM
Shhh! Keep it quiet!
06/08/2007 2:44 AM
SORRY?
Register to Reply 3 comments
You might be interested in: Control Valves, Gas Valves
