Previous in Forum: Taking Control of Noise   Next in Forum: About Material Characteristics
Inconel Axles
06/05/2007 1:38 PM
I have received word that some people are using Inconel (unsure of which alloy) for a racing kart axle instead of the typical mild steel or chromoly. The axle is basically a 1.25" tube, 32" to 36" long, and 3/16" or 1/8" wall thickness. The axle is designed to flex to aid in handling. Differences in flex will show differences in handling.
From what I have researched, Inconel is used in applications where corrosion and/or high temperatures are a factor. Would anyone have an idea why someone would use this in our application?
Thanks.
Re: Inconel Axles
06/06/2007 12:05 AM
As you rightly identified the material is chosen to avoid corrosion (and partly the erosion) becuase of the exposure of the vehicle bottom exposed to.
Inconel is a very common material in process industries.
Re: Inconel Axles
06/06/2007 6:11 AM
Are there weight savings whilst achieving same strength??
Re: Inconel Axles
06/06/2007 3:03 PM
In this application, a weight savings doesn't make a large difference in performance. Flex in the axle is the most important aspect. That being said, it never hurts to lower the rotating weight.
Good Answers: 18
Re: Inconel Axles
06/07/2007 12:48 AM
Inconnel is nickel based alloy and has different alloy combinations to suit the applications. some are ni-cu, ni -cr, ni-cr-mo. ni-fe-cr, ni-cr- al- ti etc.,
Aprat from its resistance to corrosion , they have good mechanical strength, chemical resistance at high temparature,high toughness and ductility at low and high temparature.
Hence the use of it for as pipes to avoid sea water corrosion as well as in automobile sector.
sridhar
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Re: Inconel Axles
06/07/2007 11:27 AM
INCONEL® INCOLOY® MONEL® NILO® NIMONIC® UDIMET® are special alloys to withstand heat, corrosion, erosion, abrasion, wear, and retain high strength and resistance to oxidation at high temperatures.
MONEL is a nickel-copper alloy. The two types of monel are 400, and K-500. Monel alloy 400 has approximately 2/3 nickel and 1/3 copper. Monel alloy K-500 is similar, except that it has 3 % aluminum. Monel 400 has exceptional qualtities of strength, versatility, and resistance to heat and corrosion. K-500 is heat treatable, and is, in effect, a high strength version of the 400 alloy.
INCONEL is a nickel-chromium alloy. Alloy 600 contains about 76% nickel, 16% chromium, and 7% iron. This alloy is an outstanding material for applications where fastenings must retain high strength and resistance to oxidation at high temperatures ranging up to 1600 degrees.
Abdel Halim Galala (1); Anonymous Poster (3); SRIDHAR (1)
