Previous in Forum: Training: Substation Design & Construction   Next in Forum: Frequency Converter
Insulation Monitoring
09/30/2013 5:21 PM
Whats the insulation of an insulation monitor? I want to install a permanent insulation monitor to give real time readings between two levels on a bridge crane.These levels need to totally isolated from each other.I was concerned that my instrument is going to contribute to the problem.
Re: insulation monitoring
09/30/2013 5:50 PM
"Whats the insulation of an insulation monitor"
Wouldn't your "insulation monitor" vendor be the one to ask?
Have you asked their tech guys?
09/30/2013 6:12 PM
The answer is 42.
If you desire a more concise answer without Golgafrincham obfuscation then you should be more precise on how isolating electrical insulation of a mechanical machine like a crane can be monitored. You might start with explaining monitored for what? (Sway from vertical during a quake, lightning protection to the power grid)
09/30/2013 8:09 PM
Re: Insulation Monitoring
10/01/2013 3:03 AM
First of all, obtain a detailed script of what it is that needs to be monitored. Ask the five W questions: What/Where/When/Why/Who.
Then do this with the equipment vendor:
Good Answers: 804
10/01/2013 11:55 AM
There are continuous insulation monitors for motors, but they work by checking the insulation while the motor is Off, it cannot work while the motor is running.
Good Answers: 116
10/01/2013 5:11 PM
Insulation monitor EMR4-R ??
http://ecat.moeller.net/catalog
10/01/2013 10:39 PM
These guys can help you out.
http://www.bender.org/BENDER_Products/products_bender.html
I used their products on a shipboard unground power system (270 VDC and 28 VDC).
Good luck with your quest.
Register to Reply 7 comments
67model (1); Brave Sir Robin (1); IdeaSmith (1); JRaef (1); lyn (1); PWSlack (1); redfred (1)
