Fellows, I have to know. HV CBs are said to have transient recovery voltage (TRV). When interrupting a fault the contacts will separate as a result an arc will form. But as the contacts separate the dielectric strength between the contacts increases. There will then be a race between the increase rate of the dielectric strength and that of the TRV between the contacts. if the dielectric strength is faster then the CB is good. I would like to know what causes the TRV to increase. I know the rate of increase depends on the systems connected on the terminals (contacts) of the CB. There is also small currents that are caused by capacitive or inducitve loads which the circuit breaker must interrupt. How are these currents generated and what magnitudes are we looking at?
