Previous in Forum: For 415 Voltage Why Cable Rated in 1.1KV...???   Next in Forum: Lockout Relays
Regarding Short Circuit MVA
10/07/2013 12:42 PM
In a large interconnected power system consider three buses having short circuit capacities 1500 MVA at (1 bus) 1200MVA at (2 bus) 1000 MVA at(3 bus)respectively.the voltages of all the buses are 1.0 per unit.If a three phase fault takes place on bus 2 the change in bus voltages are related by. say the relationship between ΔV1, ΔV2 & ΔV3
Good Answers: 444
Re: REGARDING SHORT CIRCUIT MVA
10/07/2013 1:26 PM
Good guess, but most of us at CR4 have done our homework long before we showed up here, so we don't want to do it again...and the rules prohibit it. (Hint: what governs the relationship between the busses?) If you want more help, tell us what the post-fault voltages are at each bus.
10/07/2013 2:25 PM
OK, I'll say, " the relationship between ΔV1, ΔV2 & ΔV3".
Anything else you want us to say?
I'll just say, "do your own homework".
Also, if you have a short circuit, the fix is to lengthen it.
(Sometimes I scare myself with my own brilliance)
Re: Regarding Short Circuit MVA
10/07/2013 7:59 PM
come on man, at least rephrase the question enough so it sounds like it's an actual problem you're working on in a Field application
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/08/2013 4:58 AM
"I was working at the local substation, when suddenly a a backhoe hit the 3-phase delta cables underground, that are connected to bus 2, shorting them all together. Because someone has borrowed our hot stick, I cannot measure the voltages, I must calculate them."
BSEE but always learning
10/08/2013 12:49 PM
not bad
10/09/2013 3:25 AM
Er, so why do the circuit protective devices not operate, thereby lowering the voltages to zero?
10/09/2013 7:44 AM
that was part of the homework question
Register to Reply 7 comments
1capybara (1); Fredski (3); lyn (1); PWSlack (1); RAMConsult (1)
