Previous in Forum: Cable Gland and Plug Application on I.S Application   Next in Forum: Difference In Increased Safety & Intrinsic Safety
I.S and Non-I.S Cable Separation
10/08/2013 2:51 AM
In my understanding , I.S blue cable can be laid with NON-I.S cable by keeping minimum 2" spacing or metallic partition between I.S cable and Non-I.S cable according to NEC.
On my plant, ALL tray (for main cables) with two section by using metal separator has been applied from different Field area upto DCS rack room. Some of Trays from different sources are intersected ( eg. Tee or Cross tray section ) in several of area etc….in this case I.S cable/Non-I.S cable should be unavoidably mixed in cross area to be routed upto required destination….
I could not find any explanation per Code/standard, and could anybody please let me know if this is ok and inform the specific any reference from Code/standard….
Pathfinder Tags: cable separation
Re: I.S and Non-I.S Cable Separation
10/08/2013 11:42 AM
Just don't lay any I.S blue cable close to any orange cable. The colors may bleed over.
(humor)
10/08/2013 7:41 PM
Thanks for reply....As explained, overally keeping separation is followed, but only very short area in tray fitting due to different direction of each cable have mixed case unavoidably...and I try to find kind of justification.
10/08/2013 9:28 PM
Without knowing where your plant is located, or what code requirements are in effect, it's hard to say.
Good Answers: 21
10/09/2013 2:51 AM
If the "blue" cable is in fact a twisted pair, or if the "blue" cable is properly shielded and earthed, then there is no problem. The reason for the spacing and / metal barrier is to prevent electro-magnetic induction in the IS cable.
Sometimes, practical and cost considerations override standard practice on an evaluated risk basis. Is your plant running, or is this a new installation ?
10/10/2013 7:47 PM
Dear Mr.Hiton,
Thanks for your clear explanation..
Based on this, I also found the description through IEC which shows "No segregation is required if metal sheaths or screens are used for the intrinsically safe or non-intrinsic safe circuit.", and I reallized that some of customer do not need separation even whole run of cables due to such reason.
10/09/2013 3:35 AM
British Standard 5345 and its ISO equivalent.
Anonymous Poster (2); Hilton (1); lyn (2); PWSlack (1)
