Previous in Forum: Compressor Shutoff (CSO) Question   Next in Forum: Name of the Support
9 comments
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Air Compressor Capacity Unit
10/11/2013 1:50 AM
hi all,
I wish to know if my understanding is correct or not.
If i say that Standard Temperature & Pressure condition is:
Temperature = 60oF
Pressure = 14.4 psia,
then am i correct in telling that the unit of compressor capacity is in SCFM.
Please clarify as many sources with various different definitions of STP & NTP are confusing.
Thanks in advance for the help.
varun
Varun Passi
Pathfinder Tags: Compressor capacity STP & NTP
Good Answers: 109
Re: Air Compressor capacity unit
10/11/2013 2:54 AM
If you define the standard temperature and pressure condition then you have to calculate the capacity based on these values.
But you can nominate any other condition and calculate the capacity for the new condition.
There might be different values for different conditions.
The key is the PVT (pressure volume temperature) constant.
In general capacity should be given for standard conditions.
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
10/11/2013 3:09 AM
This is done because the volume of a gas is dependent on the pressure and temperature. I have worked with natural gas, and there, we use SCFM and ACFM to differentiate between standard and actual flow rates.
Standard cubic feet per minute (SCFM) is the volumetric flow rate of a gas corrected to "standardized" conditions of temperature and pressure, making it the equivalent of the mass flow rate of the gas
It is better to fail in originality than to succeed in imitation.
10/11/2013 3:29 AM
thanks to all.
The actual concern is, I am calculating the capacity of a compressor based on inputs available from various users. The consumption unit varies from Nm3/hr to m3/hr.
When i calculate the capacity in terms of Nm3/hr, my superior asks for a reference back up which defines the NTP state which is not available. this makes me to use STP condition as it is defined in CAGI handbook.
Now my confusion is if i use STP as i mentioned in my 1st post, then the capacity of the compressor should it be SCFM or Sm3/hr.
1 of my user has also provided consumption as Nm3/hr but has stated the condition as 1bar and 20deg. C.
This is the cause of my confusion. Using the best engineering practise is good, but satisfying my superior with jus that is not working out.
Thanks again.
varun
Varun Passi
10/11/2013 3:40 AM
Note! There is a variety of alternative definitions for the standard reference conditions of temperature and pressure. STP, NTP and other definitions should therefore be used with care. It is always important to know the reference temperature and reference pressure for the actual definition used.
STP - Standard Temperature and Pressure
STP is commonly used to define standard conditions for temperature and pressure which is important for the measurements and documentation of chemical and physical processes:
  • STP - Standard Temperature and Pressure - is defined by IUPAC (International Union of Pure and Applied Chemistry) as air at 0oC (273.15 K, 32 oF) and 105 pascals
  • STP - commonly used in the Imperial and USA system of units - as air at 60 oF (520 oR) and 14.696 psia (15.6oC, 1 atm)
Note that the earlier IUAPC definition of STP to 273.15 K and 1 atm (1.01325 105 Pa) is discontinued.
1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02x10-4 m H2O = 9.869x10-6 atm = 1.45x10-4 psi (lbf/in2)
Standard volume of 1 mole of an ideal gas at STP is 22.4 liters.
NTP - Normal Temperature and Pressure
NTP is commonly used as a standard condition for testing and documentation of fan capacities:
  • NTP - Normal Temperature and Pressure - is defined as air at 20oC (293.15 K, 68oF) and 1 atm (101.325 kN/m2, 101.325 kPa, 14.7 psia, 0 psig, 29.92 in Hg, 760 torr). Density 1.204 kg/m3 (0.075 pounds per cubic foot)
SATP - Standard Ambient Temperature and Pressure
SATP - Standard Ambient Temperature and Pressure is also used in chemistry as a reference:
  • SATP - Standard Ambient Temperature and Pressure is a reference with temperature of 25 degC (298.15 K) and pressure of 101 kPa.
ISA - International Standard Atmosphere
ISA - International Standard Atmosphere is used as a reference to aircraft performance:
  • ISA - International Standard Atmosphere is defined to 101.325 kPa, 15 degC and 0% humidity.
ICAO Standard Atmosphere
Standard model of the atmosphere adopted by the International Civil Aviation Organization (ICAO):
  • Atmospheric pressure: 760 mmHg = 14.7 lbs-force/sq inch
  • Temperature: 15oC = 288.15 K = 59oF
10/11/2013 3:58 AM
Thanks again Economist.
Will remember your explanation.
Varun
Varun Passi
10/12/2013 7:23 AM
For air compressors, the Nm3/h means air temp at 25 deg C, and 1 atm pressure.
The N stands for Normal. Usually, the specs will allways mention the conditions under which the values are given.
For your consumers: You need to clarify the conditions. It is the best way to avoid having confusions. Once the conditions are specified, it does not matter which system of measure you use: the capacity can be m3/h or CFM. Before mentioning S for standard, define the Standard used!(convert CFM to m3/h or vis-versa )
Good Answers: 67
10/16/2013 10:54 AM
In our organization the Nm3 means gas volume at a temp of 0 deg C, and 1 atm pressure. But I really don't know from which definition we follow.
10/16/2013 12:52 PM
There must be an international agreement to normalise the definitions.
Compressed Air equipment manufacturers normally use Normal as being either 15 drg C or 25 deg C, and Usually under 1 atm pressure.
But you can check and ask the supplier (or the specifiers) to clarify their definition.
Re: Air Compressor Capacity Unit
10/16/2013 11:22 PM
Sorry for the late reply.
Thanks to all for their replies. It is better to formalize the conditions.
However use of different standards opt for different values.
Eg. As per CAGI handbook chapter 8, STP is as I mentioned in the 1st post. There are no reference books to define the term NTP (as far as I have googled).
As per IUPAC 1 bar and 0deg.c are STP, which again has been refered to as NTP above.
Anyways thanks to all your valuable replies.
Varun Passi
Register to Reply 9 comments
Economist (2); IdeaSmith (1); LAA_Lucke (2); pritam (1); varunpassi (3)
