Previous in Forum: In What Ways Have You Seen PLC Failure?   Next in Forum: Liquid Rotor Starter
9 comments
Two Source VFD Advantage
10/11/2013 11:30 AM
what are the advantage of two source (star & delta) VFD than one source ( star) ?
Good Answers: 444
Re: two source VFD advantage
10/11/2013 11:42 AM
Flexibility, Source-load can be configured Y-Δ or Δ-Y for harmonic reduction/elimination, depending upon source vector group.
Good Answers: 804
10/11/2013 11:51 AM
Not sure what you mean by this. Maybe you are asking for the difference between a 12 pulse front end and a 6 pulse front end drive? The 12 pulse version would typically have two separate bridge rectifiers fed with two transformers, one with a Delta secondary, the other with a Star (Wye). The purpose of this is to create a phase shift in the feed that offsets much of the harmonics created by the rectifiers and thus reduce the THD.
On a 6 pulse drive, the line being Star or Delta has only to do with your incoming voltage. For most systems outside of North America, the Star voltage is 400V nominal phase-to-phase. A 6 pulse drive has no harmonic mitigation inherent to it, you deal with that after the fact with reactors and/or filters.
Good Answers: 117
10/12/2013 12:16 AM
a 12 pulse doesn't have filtering either, unless you spend a small fortune. In fact in the US, certain state utilities have now threaten to take users of 6 & 12 pulse drive to to federal court if they don't disconnect the drives all due to harmonics exceeding IEEE519.
Good Answers: 804
10/12/2013 1:39 PM
Really? Never heard that. Sounds like a fear mongering urban myth started by someone trying to sell harmonic mitigation systems. The harmonics of an individual drive are inconsequential in many many circumstances, what is important to the utility is the THD at the Point of Common Coupling. If I have a single 100HP 6 pulse drive on a system with a 4000A total load, my THD at the drive could be 100% and it would not cause the PCC THD value to exceed IEEE519. How you attain reduction of the TDD at the PCC is also completely irrelevant. Threatening to force disconnection of 6 or 12 pulse drives because of their individual contribution is not something any reasonable engineer would support.
That said, I believe that 12 pulse is not worth the effort, 18 pulse is far better for only slightly more. But thats not what the OP asked.
Better yet if you have multiple drives is an Active Harmonic Filter. But again, only if NECESSARY because someone has determined that the percent of non-linear load compared to total load at the PCC warrants it.
Good Answers: 117
10/12/2013 2:05 PM
Not my style, I speak from reading the hard evidence.
Good Answers: 804
10/12/2013 7:08 PM
Sorry, didn't mean to imply that YOU were the one making that up, only that was the likely original source of that information. I have heard stories similar to that bandied about by salesmen bent on selling their particular solution equipment, or even consultants trying to drum up work.
I'm working on a project right now where there is a small Motor Control Center with an 800A bus filled with VFDs, every one of which is required to have a passive harmonic filter on the OUTPUT side of the VFD, ie going to the motor. Not a sine wave filter to prevent standing waves or bearing EDM damage, but a HARMONIC filter. The concept is preposterous. When I asked the Consulting Engineer why, I discovered he is an ME, but he had spoken to a rep for a line of sine wave filters who told him it was a new regulation. Pure BS...
10/15/2013 10:53 AM
Dear Mr.JRaef,
You are absolutely right.
DHAYANANDHAN.S
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Re: Two Source VFD Advantage
11/19/2013 10:17 AM
this
http://www.yaskawa.com/site/dmdrive.nsf/%28DocID%29/MHAL-6JETW2/$File/WP.AFD.02.pdf
shows the 6-pulse drive as over IEEE standards but the 12 and 18 pulse drives as meeting IEEE 519 limits.
BSEE but always learning
Good Answers: 117
11/19/2013 10:26 AM
I think you will find that is at FULL LOAD, anything below ... forget it!!
Register to Reply 9 comments
1capybara (1); brich (3); dhayanandhan (1); JRaef (3); RAMConsult (1)
