Previous in Forum: Two Source VFD Advantage   Next in Forum: Neutral Cable Size
Liquid Rotor Starter
10/11/2013 11:53 AM
How to calculate the final shorting time of LRS electrode? And also how much liquid pH should be maintained?
Pathfinder Tags: LRS
Re: Liquid Rotor Starter
10/11/2013 12:36 PM
Here:
IS CODES- indian standards - Egpet.net
Or, here:
bureau of indian standards codes
Or, if homework:
Tips for Posting on CR4:
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
  • Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
Good Answers: 181
10/11/2013 9:30 PM
I found experimentation with the real kit best.
Start with the manufactures recommendations and then play.
By watching the main ammeter you can tell if the electrolyte is right by its initial and final current draw. The time is shown by the current stability during the start up.
You can calculate to the Nth degree, it won't match the real start up.
Good Answers: 42
10/12/2013 4:34 AM
If you have not still purchased the starter see[for instance]:
http://www.nhp.com.au/files/editor_upload/File/Brochures/Motor-Control-and-Drives/NHPLRSC.pdf
and fill the form "LRS design and selection guide".
(or Google "Liquid Resistance Starter ".)
If you have already purchased the starter you have all the motor data for calculating [using Steinmetz Diagram].
Julius
Register to Reply 3 comments
7anoter4 (1); lyn (1); TonyS (1)
