Previous in Forum: Mechanical Engineering Divisions for Master   Next in Forum: Repair of Centrifugal Compressor
15 comments
Flow Calculation
10/12/2013 2:15 PM
I want to know is their any method to calculate flow form system without flow meter & any other meter
Re: Flow calculation
10/12/2013 2:33 PM
Doesn't matter much what you decide to call your measure method. Whether using a yardstick in a barrel or a floating ball and marks on a wall or a counterweighted tank that goes up and down; it's a meter.
10/12/2013 2:46 PM
Not without more information.
10/13/2013 12:42 AM
This is not flow from fix cantainer... We have chiller which has fix chilled water circulat from system Production dept. Takes chilled water use it & give us back after incrise temp. So how can I know how much flow going in which plant.
10/14/2013 6:02 AM
Why is the knowledge of the flow of any particular value?
10/12/2013 3:14 PM
these are NEVER wrong, accurate to within a millionth of a litre
Good Answers: 203
Re: Flow Calculation
10/12/2013 11:36 PM
Take a container, preferably a cylinder shape, a tape measure or other distance measuring device and a stop watch or wrist watch.
Start the unit under test, let the fluid fill the container for a predetermined length of time. Measure the height of the fluid, calculate the volume of fluid, divide this by the elapse time of the flow and you get the volume per time or volume/time. Some examples of this could be: gallons/minute; liters/hour; ounces/day, barrels/year or shot glasses/hour.
Good Luck, Old Salt
Location: crankshaft producing hub in belgaum,karnataka,india
10/12/2013 11:52 PM
Take an empty used barrel of standard 205 ltr capacity, fill it upto brim, and measure the time needed. 205 ltr / time in sec gives the flow per second .
10/13/2013 12:37 AM
10/13/2013 7:17 AM
you don't
Good Answers: 183
10/19/2013 1:29 PM
You are very precise would you recommend same barrel for a flow of 0.1 l/min and an other for 1500 l/min ?
10/13/2013 12:34 AM
10/13/2013 1:11 AM
Really?
Do you have no information on the capacity of the equipment?
Have you no one there who knows how to estimate flows based on pipe diameters, lengths, etc? Drawings? Specifications? Engineers?
You have no idea of the pressures in the system?
You can't buy a clamp-on flow meter and get some real numbers?
Hire an engineer! Spend a buck!
Reply Score 1 for Off Topic
10/13/2013 6:53 AM
You can look at the increase in temperature. then compare it to the energy input for a corresponding part of the chill water loop.
Alternately, you can look at the temperature reduction and then compare that to the change in temperature, flow, and thermal characteristics of the fluid to which the chill water system is rejecting heat.
Good Answers: 183
10/19/2013 1:32 PM
In such a case of course no flow meter is required but a more complex energy meter to know how much energy was injected in the water flow. It is to make a choice either flow or energy one of them has to be quantified.
10/19/2013 6:44 PM
There may not be a need for a 'complex energy meter', but it all depends upon what information IS actually available.
If you had a good idea about the amount of heat expelled by the chill water system (knowing flow rate, ΔT and thermal characteristics) , then you could make decent estimates of the total chill water flow with just the chill water ΔT.
There really isn't enough information provided, and I am beginning to think perhaps it was homework.
Reply to Forum Thread 15 comments
Fredski (2); Kedarnathsingh (3); lyn (2); N. (1); nick name (2); old salt (1); PWSlack (1); ravi bagewadi (1); truth is not a compromise (2)
