Previous in Forum: Welding of Weldolet - How Much Fillet Required?   Next in Forum: G.I. Pipe Welding
Tank Internal Heating Coil - Is It Under API 650 or API 653 or ASME B31.3?
10/13/2013 12:15 AM
Dear All,
Please advise, heating coil for new tank (API 650) and modification tank (API 653) are under which code for design, inspection and testing?
Thanks
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Re: Tank internal heating coil - Is it under API 650 or API 653 or ASME B31.3?
10/13/2013 2:39 PM
I can tell you that they do not fall under ASME B31.3
It is better to fail in originality than to succeed in imitation.
10/13/2013 3:50 PM
In the red circle, the heavy line entering at the top says otherwise--that the piping does need to conform to ASME B31.3. (Which makes sense, by the way.)
10/13/2013 4:29 PM
Yes, ASME B31.3 application ends where the pipe enters the tank, as you can see. Inside the tank, you can see its a thin line, therefore out of scope.
I don't know which standard applies for internal heating coils. Do you?
10/13/2013 5:04 PM
It may depend on whether the coil is welded to the tank, versus entering and leaving independently. Jurisdictional conflict is typically silly, but that won't stop it.
Re: Tank Internal Heating Coil - Is It Under API 650 or API 653 or ASME B31.3?
10/14/2013 9:26 AM
Thanks all.
Hi Torando,
Both nozzles of heating coil welded with shell plate and entering and leaving independently.
If we use, B 31.3 for design, inspection and testing, is there any problems?
But our designer also not specify this and we follow B31.3 for inspection and testing requirements.
Economist (2); Shavessels (1); Tornado (2)
