Previous in Forum: Closure Weld Requirements for Lines Designed According to ASME B31.1   Next in Forum: Tank Internal Heating Coil - Is It Under API 650 or API 653 or ASME B31.3?
Welding of Weldolet - How Much Fillet Required?
10/10/2013 10:05 AM
Dear All.
Please advise for the below.
As per B31.3, for branch connection welding we follow below,
"328.5.4(d) Branch connections, including branch connection
fittings (see paras. 300.2 and 304.3.2), which abut the
outside of the run or which are inserted in an opening
in the run shall be attached by fully penetrated groove
welds. Thewelds shall be finished with cover filletwelds
having a throat dimension not less than tc. See
Fig. 328.5.4D sketches (1) and (2)"
Question: What about weldolet welding? Addition to full weld penetration at groove of weldolet,
do we need finish with cover fillet welds having a throat dimension not less than tc or
cover full groove of weldolet?
How to calculate Tb(nominal thickness of branch), is it weldolet thickness( sch, eg; 1.5" sch 80 (5.08mm)) at butt weld location or heavy thickness of weldolet bottom?
We want to weld weldolet 1.5" sch 80 in 6" run pipe.
Re: Welding of Weldolet - How much fillet required?
10/10/2013 10:16 AM
No joy over the phone with the weldolet manufacturer, then?
Good Answers: 104
Re: Welding of Weldolet - How Much Fillet Required?
10/10/2013 1:26 PM
This question was addressed here:
http://cr4.globalspec.com/comment/917696
10/11/2013 9:51 AM
Weldolets are "Branch Connection Fittings", therefore they require cover fillet welds.
The throat dimension of the cover fillet weld in your case would be the lesser of 1/4" or 0.7 x 0.200" = 0.14". A fillet weld leg size of 0.200" should meet this code requirement.
Register to Reply 3 comments
bigg (1); Mechanicalmark (1); PWSlack (1)
