Previous in Forum: Quality Control   Next in Forum: Welding of Weldolet - How Much Fillet Required?
15 comments
Closure Weld Requirements for Lines Designed According to ASME B31.1
10/01/2013 9:10 AM
Dear Experts,
after conducting the HT we have many joints that not subjected to HT, and we are asking the contractor to let us to do the in-process inspection and to conduct DPT inspection after root pass and 100% RT for the final weld, but he is asking for the reference for our decision but unfortunately we fail to find the support from the code not like B31.3 the statement is very clear,
Pls help me on this issue,
Thanks in advance.
Pathfinder Tags: ASME B31.1 Closure Weld
Good Answers: 104
Re: Closure Weld requirements for lines designed according to ASME B31.1
10/01/2013 9:36 AM
Without knowing the pipe material, wall thickness, conveyed fluid, etc., it's impossible to know why HT (are we talking about oven heat-treatment?) is required. Why do you think additional examination eliminates the need for heat treatment/stress relief?
Good Answers: 104
10/01/2013 5:30 PM
OK, so we're talking about HT = hydrotest, HT ≠ heat-treatment as I assumed. That makes more sense. Ignore my previous response.
10/01/2013 10:30 AM
I'm not sure this will help, but you might see how "golden welds" are handled in the code you are using.
What is keeping you from doing the hydrostatic test on all but a few final welds?
10/01/2013 12:30 PM
Thanks to all The problem is that the contract specs is little bit weak, though it's not mentioned there, but any better to follow tornado suggestion and SURE it will work ;)..
10/01/2013 1:18 PM
Then write off any extra costs to it being a learning exercise, never to be repeated:
  • There's a story about a young Engineer, who was asked to go and do something out on the plant that was beyond then-current skill sets. A calamity happened, and £500,000GBP worth of product went off-spec. Called in to the Manager's office and expecting to get fired, the Engineer was surprised and relieved to discover being kept on the payroll. In response to the question why this was to be the case, the Manager replied, "Because I have just invested £500,000GBP in your training, and I am determined to get a return on that investment!"
10/01/2013 5:53 PM
No problem if neglecting a few amoune of joints but for more assurance we will try to push the contractor to do it neglecting some minor issues on project specs. But if I find the clear statement it will be very nice. Thank you.
Re: Closure Weld Requirements for Lines Designed According to ASME B31.1
10/01/2013 11:52 AM
Well, if it's opinion-based requirements, then the contractor is entitled to be paid for any inconvenience arising due to being asked to do extra things that were not specified when tendering and at contract award.
So the answer to the query depends upon what is in the contract documents, which probably commercially sensitive, and therefore should not be revealed here. In any case, they cannot be seen from here at this time.
So good luck in sorting that one out.
<unsubscribes>
Good Answers: 109
10/01/2013 1:31 PM
I get mixed messages here. So it might be better to explain:
What is HT, RT, DPT???!
I was thinking HT is Hydro Test, but I am not so sure anymore and DPT does not make any sense.
10/01/2013 2:15 PM
Hydro test, radiography test, dye penetrant test.
10/29/2013 4:47 AM
Mr IDEASMITH,
HT = HYDRO TEST OR HEAT TREATMENT.
RT = RADIOGRAPHY TEST
DPT = DYE PENETRANT TEST
ALL ABOVE TEST MAY BE REQUIRED TO BE CARRIED OUT IF LINE CLOSURE WELDING IS TO BE CARRIED OUT UNDER THE CODE ASMEB31.1
10/02/2013 2:48 AM
HT - Hindustan Times
DPT - DPT Vaccine
RT - Russia Today
Codes are just guidelines to ensure MINIMUM safety of the public from a catastophic component failure. Your client/consultant, Main contractor and sub-contractor need quality education from reputed universities currently available in the world before going for this kind of work.
Diesel mechanic
Good Answers: 67
10/02/2013 4:20 AM
One golden joint with DPT at root run and 100% RT while hooking up the newly erected pressure piping is normally allowed but specifically is not found in codes.
10/03/2013 3:35 AM
It is more of contractual matter rather than looking for code to allow checking quality of work by the Owner or his Rep. There must be Articles in the Contract Agreement where it has been described Contractor's Right and Owner's Right. Owner always has upper hand regarding acceptance of Contractor's Work. I see no problem convincing Contractor that it is according to Agreement. One has to go through the General Condition of the Contract Agreement.
Good Answers: 34
12/04/2013 4:52 PM
Closure welds ASME also named Golden Welds API
For me the reference on ASME B31.3 point 354.2.3 c, is very clear and a valid support for you.
Register to Reply 15 comments
Anonymous Poster (1); bigg (2); dolby (1); IdeaSmith (1); Mohd Elfatih (2); pritam (1); PWSlack (2); rajan_bhiwandkar (1); Tornado (2); user-deleted-1100 (1); Whitephone (1)
