Previous in Forum: ASP.net   Next in Forum: ASP.net Print a Content of Page
ASP.net
10/16/2013 2:01 PM
How to generate a report without using crystal report?.And also how to generate check box dynamically in datagrid without using default template an those check represent particular field in database table?.
Re: ASP.net
10/16/2013 3:10 PM
Are you guys in the same class?
Re: ASP.net
10/16/2013 4:36 PM
Good Answers: 117
Re: ASP.net
10/17/2013 1:01 AM
you found this site by searching for an answer to your problem.... keep searching!!
If you don't, you will NEVER learn anything!!
Re: ASP.net
10/17/2013 1:20 AM
RTFL (L=Literature; preferably specific to ASP.net... a textbook maybe?)
Re: ASP.net
10/17/2013 9:55 AM
Without clicking a button how do you know the report should be printed? You might trigger the print by the completion of a retrieve but that will waste a great deal of paper. Your requirements are naive. The button allows the user to get it right before printing. You will need to retrieve the data into a table and print the table. You will need to do all the calculations, sorting etc in the select statement.
aDIYguy (1); brich (1); lyn (1); Mikerho (1); Tornado (1)
