Previous in Forum: Valve Shaft Material   Next in Forum: MDMT and Impact Test in A36/6mm Storage Tank
11 comments
How to Know Oil Specifications Acceptance Range?
10/27/2013 6:31 AM
good day
im working in Oil & Gas company. we are dealing with many rotating Equipments such as
reciprecating Compressors , Centrifugal pump/compressors & Power turbine.
we use many type of lubricants for these equipments.
the Manufactrer of these equipments only provide the specification of the fresh new oil that should be used. he did not provide the allowable range for the specifications.
1- how to know the allowable range (acceptence range) of this oil?
2- is there standards such as api -astm- ase- iso or others that rule or mention the acceptence range of the oil?
best regards.
Re: how to know oil specifications acceptence range?
10/27/2013 7:51 AM
There should be a maintenance schedule for each piece of equipment, in your literature. Change the oil at the recommended intervals, along with any other routine lubrication and checks.
Good Answers: 183
10/27/2013 7:52 AM
As far as I know ONLY the equipment manufacturer who made the validation tests for the oil quality can give such limits.
In fact the recommended time to oil replacement is a measure of acceptable limits since quality loss is for a given machine proportional (in some respect) to working cycle and time.
10/27/2013 8:40 AM
ASE and and others like them will only rate a given product for its performance under specific tests. they will "pass" or "approve" it and give their stamp of approval. they will not however advise you on change intervals or anything maintenance related, you must consult the manufacturer of each given piece of equipment for that information.
10/27/2013 11:19 AM
Do some research:
Extending Oil Change Intervals on Heavy Mining Equipment
Five Strategies for Extending Machinery Life
3 Ways Oil Analysis Extends The Life Of Your Engine | Cardwell ...
Extending the oil change interval of your equipment MAY VOID THE MANUFACTURER'S WARRANTY!
Check first.
Re: How to Know Oil Specifications Acceptance Range?
10/28/2013 12:55 AM
Lubricant provider may also give you the limiting acceptable range for various parameters for lubricating oil and its replacement frequency.
10/28/2013 4:38 AM
Dear Mr.midofnowhere,
Pl. open the link below, which is a LUBRICATION related subject.
http://www.machinerylubrication.com/Read/329/inspection-lubrication
At the bottom, you will see "RELATED TOPICS" If you open any one of it, you will again find few more RELATED TOPICS. Perhaps, you may get an answer, for your quiery. Get registered there, and you will regularly get mails from them. A good EDUCATING matter.
DHAYANANDHAN.S
Good Answers: 183
10/28/2013 4:47 AM
Considering the answers you got I feel necessary to add some remarks.
During usage the basic properties of lubricating oil will change due to shear and temperature effects. In general the operations have as scope to clean the oil since contained particles have a wear effect on sliding surfaces and also interrupt the oil film in the most loaded regions. Water contain has a chemical effect &as well as presence of metal particles which are due to their form and surface chemically active.
With time oil molecules break and lubricating properties as viscosity do change. This loss of portance for the oil films cannot be avoided by simple cleaning. Thus the need to make a full analysis of samples in order to know the loss level.
This "destruction" depends on working conditions as for instance sliding velocity, specific load on film and temperature or/and water content. Only the manufacturer can define the limits by the prototype tests. It is possible to make some similitude but it could be dangerous. For safety reasons it will specify an inetrval for which the losses are small enough to avoid catastrophic failures.
This is the reason why in Lyn' s comment it is mentioned that insurance will not cover machines working with cleaned oil since even if particles and water were eliminated the loss in film portance is still present!
10/29/2013 2:08 AM
thank you all for your feedback
we contact the manufactrer and ask him for the accepted range for the oil specifications
but the manufactrer didnt provide us. he only gave us the recommended time to change the oil ( example each 5000 runing hours ).
if i only stick on this rule(the recommeded time to change the oil), there will be no point of the rotine lube oil analysis.
i will give you easy example :
the manufactrer said the recommeded time to change the oil 5000 hr. after 2000hr the water content increase, or there was some process gas leak into the lube oil & the flash point drop, or there was too much wear on the machine which resluts on increasing of the solid & metals content.
is it wise to stick on the recommended time to change the oil? or you should have on your hand aceptence range (for flash point, water content, solid & metal content viscosity etc) and do oil analysis to check if you are on the safe side or you should have early action?
because of that im in situation i need to know how to Know Oil Specifications Acceptance Range?
i think there should be a standard or method or a fourmla which answer my question.
10/29/2013 3:54 AM
Typically, the oill change schedule is based on real life tests on the actual equipment, but if you are seeing problems before that time, here are some numbers and codes that may help. These are numbers for turbine oil, but should give you a general idea of when a change is needed.
http://www.machinerylubrication.com/Read/300/turbine-oil-performance
10/29/2013 5:45 AM
I'm surprised that the manufacturer did not state that the suggested oil change intervals were for "normal" conditions, and that shorter change intervals might be required under conditions such as those you describe.
Your operating conditions suggest that you should analyze your oil, and perhaps change it more frequently than suggested.
Good Answers: 183
10/29/2013 10:57 AM
Start to build up YOUR data bank taking every 1000h a sample and making all pertinent analysis. This will correlate them to YOUR working conditions the manufacturer does not know exactly how YOU will use the machine.
This way you will have an indication about the trend and may be you will be able to change every 10.000 h in stead of 5000. This is the BEST approach if either the machine is very big and expensive or there are many machnies in use and conditions are far from "normal". It is expensive but it could pay back.
Register to Reply 11 comments
dhayanandhan (1); Fredski (1); IRSHAD (1); kramarat (2); lyn (2); midofnowhere (1); nick name (3)
