Previous in Forum: How to Know Oil Specifications Acceptance Range?   Next in Forum: How to Classify Pumps?
MDMT and Impact Test in A36/6mm Storage Tank
10/27/2013 1:22 PM
Hi everybody!
There is a Storage Tank for water and they are asking me for the MDMT, but i dont know how to read the Table 4.1 in API650. They want to know this info for determinate Impact Testing is required or not?
Fluid: Water (6°C Aprox)
Min. Air T°: 0°C
Max Pressure of Vessel: 3 PSI(storage tank)
Material: A36- th=6mm
So.... is required impact test in this case? What is the correct way to read the table from API650 4.1? Whay about the equations 4.3?
Please I need your help. Thanks!!
Re: MDMT and impact test in A36/6mm Storage Tank
10/27/2013 2:03 PM
How about quoting the relevant sections of API650, so that the rest of us can read them?
Good Answers: 114
10/27/2013 2:58 PM
Minimum Design Metal Temperature.
http://www.gowelding.com/weld/fracture/impact.html
Re: MDMT and Impact Test in A36/6mm Storage Tank
10/27/2013 11:22 PM
Are you sure that table 4.1 discuss about MDMT and thickness? Which edition of API 650 is your reference? If possible could you attach that table here for a deeep analysis?
10/28/2013 1:43 AM
Yes, in other edition of API650 the table is 2.1 (Minimum Permissible Design Metal Temperature for Materials Used in Tank Shells Without Impact Testing)
my question is 1.how can I stimate the MDMT for that conditions on the storage tank? (air tempreature 0ªC, and water=6ªC)
2. For that conditions is necessary impact test?
10/28/2013 2:02 AM
Any bet ? ROFL
Dude, first read the standard carefully and ask questions Otherwise attach the table for a deeeeeep analysis
10/28/2013 3:21 AM
According to your data, the lowest temperature to which the tank would be exposed is 0°. The code may require some "cushion" such as a designated MDMT of somewhat less, such as -10°C. Then the table(s) should tell if impact testing is required.
Register to Reply 6 comments
Anonymous Poster (2); dricardo10 (1); passingtongreen (1); Tornado (2)
