Hi C-4
I am getting ready to install a second level in my shop intended to be used as parts storage space. Parts are engine parts, nuts bolts, gaskets, tools, etc. The span is 32', the intended area width is 6'. I intended to use three 10" I-Beams (25.4 lb/ft).
I am no structural engineer by any means and my standard MO is to install these and if deflection is noted then go on to "plan-b" that would include adding a support column under the span, but I don't want to do this.
If anyone out there could tell me what the un-equal load capacity of the three beams would be, it would be greatly appreciated.
I would rather go with heavier if needed to be sure the support column is not needed.
Thanks
Tim
