Previous in Forum: Removing Rust from Internal Parts   Next in Forum: 2000 Cavalier Starting
8 comments
Good Answers: 96
Temperature Coefficient
10/30/2013 6:01 PM
Dear Friends and Associates,
I hope you can help with my confusion. I work with magnet wire and coils, and I needed to find (again) the temperature coefficient of Copper and Aluminum. Sounded easy enough, but It seems everywhere I look, I find DIFFERENT ANSWERS. It makes no sense at all.
All these are given per degrees C (where there are extensive lists, I am choosing the one closest to the materials I am using)
Chemistry and Physics Handbook (yes, some of us DO still own books )
Cu = 0.0039 Al = 0.0039
Engineers Toolbox (http://www.engineeringtoolbox.com)
Cu = 0.00429 Al = 0.0038
(http://hyperphysics.phy-astr.gsu.edu)
Cu = 0.0068 Al = 0.00429
(http://hyperphysics.phy-astr.gsu.edu/hbase/electric/restmp.html#c3) NOTE these last two are the same 'company', but two different pages give different references.
AAAARRRRRRGGGGGG!!!!!!!
What in the world to do?!?!?! It seemed like such a SIMPLE thing to search. (like the lady in the spaghetti sauce commercial, "I wonder what other stupid choices I've made before?")
If anyone has the CORRECT answer, I would appreciate knowing. (it WILL be interesting to see how many different answers I get from everyone ) And, if someone could let me know what they use and believe is a consistently reliable source of materials data.
Kind regards ...
"Just when I had all the answers, they changed all the questions"
Re: Temperature Coefficient
10/30/2013 6:13 PM
Temperature coefficient of.......?
If you are going to complain about the quality of information available, at least make sure enough information is provided in your complaint......
Good Answers: 96
10/30/2013 6:58 PM
Hello Truth,
You are correct ... the issue is Temperature Coefficient of Resistivity.
Kind regard ...
10/30/2013 9:37 PM
The temperature coefficient of resistivity for copper and aluminum is pretty close to the same value.... roughly between 0.0039/°C - 0.0040/°C when close to 20°C. The coefficient will probably be different for various alloys and possibly even for different conditions of the conductor, i.e. annealed, oxygen free, under high pressure, etc.
I suspect the variation you noted either reflects values for various alloys, or perhaps reflects something other than a ratio per °C (perhaps Ω/°F ?).
Good Answers: 96
10/30/2013 11:58 PM
Thanks for the information. Can you cite your source?
It's consistent with the Chemistry and Physics Handbook, which I would hope is accurate.
Thanks for your help.
Kind regards ...
10/31/2013 10:33 AM
Here is a decent reference for copper.
I'm embarrassed to say I was going off memory, and cannot find a good reference for the temperature coefficient of electrical resistivity for aluminum. Even worse, when I estimate the coefficient using data from a reliable source, the results differ from the answer I previously provided (with high confidence).
0.0043/°C - 0.0045/°C is probably closer to the value for aluminum... so, close, but still a little bit higher than copper.
Good Answers: 96
10/31/2013 3:03 PM
Thanks for the data, and thanks for confirming how strangely difficult it is to find the data. I think what I'm going to do is (1) run with what seems the best data at the moment, but also (2) find a way to do my own confirmation. I think I can, and I probably won't need more than a few data points to confirm.
It's not really necessary, but I really need to find some substance to the data. My wife has a name for that behavior .
Kind regards, and thanks for your help ...
10/30/2013 6:17 PM
10/30/2013 6:19 PM
Register to Reply 8 comments
DCaD (3); Fredski (2); truth is not a compromise (3)
