Previous in Forum: kVA Rating Question   Next in Forum: 110V DC Power Supplies Through 240V AC UPS to 110V DC Converter
9 comments
AC Induction Motors Load Sharing
11/02/2013 8:29 AM
Dear all
is there any reference or standard for the optimum motor size for load sharing, which mean from cost and operation wise to make load sharing between motors it should be started from load requirement not less than ?? HP
i hope my question is clear
Thx
Re: AC Induction Motors Load Sharing
11/02/2013 1:08 PM
No.
Good Answers: 104
11/02/2013 1:58 PM
Load sharing?
11/02/2013 9:40 PM
Don't start them at the same time.
Good Answers: 42
11/03/2013 4:53 AM
If you would intend to put two motor of different characteristics on the same axe in order to drive a certain load then you could have such a problem. The correct load of the motor-less losses =high efficiency ,less reactive power=elevated power factor will be from 3/4 to full rated load of the motor. A suitable standard could be IEC60034-30 or NEMA MG1-or else, of course.
Julius
11/03/2013 6:36 AM
Let's hope OP is smarter than that.
Good Answers: 181
11/03/2013 7:44 PM
Highly unlikely!
11/05/2013 6:03 PM
Thx a lot, but if two identical motor is used, do you think what's motor size should be cost effective, for example use two 100HP motors instead of 200 HP one
is there any standard to guide me what is the size of motors to be replaced by two or more motors in order to achieve load sharing advantages
Regards
11/05/2013 6:11 PM
No.
Good Answers: 104
11/05/2013 6:50 PM
Why? What are you trying to accomplish? You haven't even stated the load or load characteristics which might suggest doing this.
Register to Reply 9 comments
7anoter4 (1); bigg (2); eng.hmk (1); lyn (2); TonyS (1); Tornado (2)
