Previous in Forum: How to Apply a Liquid Coating Around a Ceramic Cylinder?   Next in Forum: Caustic Service
After the Tallow is Hydrolyzed, How to Remove Glycerin and Water?
11/03/2013 8:32 PM
After the tallow is hydrolyzed to acids and glycerin, how to remove the mixture of water and glycerin in the industry of stearic acid production? Please list some common methods, corresponding principles and facilities.
Pathfinder Tags: stearic acid
Re: After the tallow is hydrolyzed, how to remove glycerin and water?
11/03/2013 8:43 PM
katty,
Where have you looked, so far?
Did you ask your professor about this?
I'll quote from a previous reply by you,
"Well, my supervisor (professor) says that you should never expect scientific help from me. I am not here to explain this to you."
So, the point is, you are a student. We are not here to do your homework for you.
If you do some research on your own and need help determining the best solution from the methods you find, someone here MAY help you.
11/03/2013 8:51 PM
You can probably find a book on the process here....
http://www.gobookee.org/process-for-stearic-acid-production/
Good Answers: 203
Re: After the Tallow is Hydrolyzed, How to Remove Glycerin and Water?
11/04/2013 11:08 PM
Katty-
Distillation
Good Luck, Old Salt
11/09/2013 1:11 AM
When you pressurise coconut oil in a fat-splitting column with water and steam,it breaks down into fattyacid & sweet water. When you concentrate(heat)sweetwater you will get glycerine.
pnaban
Register to Reply 4 comments
lyn (1); old salt (1); pnaban (1); SolarEagle (1)
