Previous in Forum: API 650 Weld Visual Acceptance Clause   Next in Forum: Sensor to Measure Oil Residue in Compressed Air
PC Pumps (API676)
11/12/2013 3:30 AM
In a situation a Progressive Cavity pump is selected for handling hydrocarbon and produced water @ 16m3/hr (rated cap), 0.6 barg (suction pressure) and 2.4 barg (discharge pressure).
The NPSHA = 1m.
Design suction pressure = 13.6 barg
Design discharge pressure = 17 barg
The recommended relief setting at discharge = 17barg is based on discharge design pressure.
As per API 676, a PSV shall not be set according to casing/piping design pressure but according to max operating pressure of the pump. The correct PSV setting as per API 676 would be maximum operating pump discharge pressure +1.7 bar.
The above will lead to oversizing of pump as it has to handle the design pressure.
Points for discussion -
(1) In case of suction reaching to its design case i.e. 13.6barg in case of emergency, will that be transferred to discharge even in case of a PC pump?
(2) What way will the pump deliver at suction design pressure, if we want it not to trip before relief setting?
(3) Any alternative suggestion for this situation?
Re: PC Pumps (API676)
11/12/2013 10:41 AM
If the process discharge pressure is 2.4Barg and the pump maximum discharge pressure is 17Barg, a relief valve set to anywhere between 2.5 and 17Barg should be the business.
Clearly, if the fluid contains flammables, spraying them willy-nilly is absurd; returning the relieved fluids to the tank at the suction is appropriate. However, if the discharge piping has nothing in it that could cause excess pressure over and above 2.4Barg then a relief valve would be unnecessary.
Best thing - subject the installation to a formal HazOp Study, and see what happens, simply because the forum cannot see the current issue of the P&ID.
11/13/2013 7:05 AM
If the suction pressure is 13.6 barg, it would stand to reason that, even if there was no pump in the line, there would still be a pressure of 13.6 barg in the system. Therefore, the relief valve would have to be set at or above that pressure. Frankly, unless I am missing something, I don't know how the writer can have an inlet pressure of 13.6 barg and a discharge pressure of 2.4 barg unless the PC pump is acting as not only a delivery mechanism but a pressure reducing mechanism as well, however unlikely that may sound. A PC pump is, by definition, a semi-positive displacement pump. That being said, if the pump rotates, something has to move. And when the pump turns, the pressure will continue to rise until something "lets loose". That is why it is always advisable to have a relief valve in the line of a PC pump. If something closes the discharge pipe completely and the pump continues to run, the only protection left is electrical (overloads on the motor starter) or mechanical as in ruptured lines, motor burn up or something equally as catastrophic. You are correct in that whatever the setting of the relief valve, the location of the discharge of that valve must be contained some how.
All that is necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
Good Answers: 117
11/12/2013 10:42 PM
You set your limit to slightly below the max pressure of the discharge tubing, do not use a PSV, use a shut down trip. STOP THE PUMP!
PCP's will continue to build pressure even if the discharge is closed, as I'm sure you know.. so stop the motor! No more pressure. I have seen a PCP split steel tubing in the oil fields...
I have no idea what you are pumping as a PCP will pump anything from live fish to peanut butter. Whatever you are pumping you don't want to have to clean it up!
brich (1); PWSlack (1); The Commoner (1)
