In machine manufacturing, we require fitting bearings. These bearings are responsible for the accuracy of the machine.
Bearing manufacturers recommend a fit ranging from 22 to 40 microns on bearings of sizes, 50 to 150 mm on their diameters and an identical clearance of around 30 microns on the shafts.
This throws the requirement out.
But the machines are expected to work with an accuracy of 10 to 20 microns.
What is the standard we can adopt to sort these type of problem.
