Previous in Forum: Cables Connected in Parallel   Next in Forum: Solution For Optimal Power Flow Problem
Shorting Links Between Brush Holders of DC Motor
11/26/2013 4:26 AM
Dear Sir
Most of the DC Motors are provided with shorting links between positive brusholders only and some of DC motors are provided with shorting links between both positive brusholders and also between negative brusholders. What was the Reasons for providing shorting links .Whether DC motors can work without shorting links dully connected armature , interpole , compensating coils and supply leads in armature circuit
Sadasivam
Re: Shorting links between brusholders of DC Motor
11/26/2013 5:51 AM
Think about it. What would happen were a DC motor to be spun mechanically while disconnected from its supply, perhaps for maintenance purposes, especially were some residual magnetism remain inside it? Eh?
11/27/2013 5:39 AM
The links mentioned are actually positive to positive brush and negative to negative brush.....
Not positive to negative which would indeed prevent a voltage being developed if the motor was turned as you mentioned, but would represent a massive short when used as a motor......
Generally there is always some residual magnetism leftin a motor/generator that a DC Generator often makes use of to "Kick-Start" generation....
Maybe I am missing something? Can you elucidate?
11/27/2013 5:47 AM
Links are being provided between positive brush holders only and similarly between negative brush holders only.Kick start generation when can happen as the DC motor is given supply and driving hoist crane and what way the residual magnetism remaining will affect the DC motor during its operation
Sadasivam
11/27/2013 9:22 AM
Back EMF. Well documented on the web.....
Good Answers: 181
Re: Shorting Links Between Brus Holders of DC Motor
11/26/2013 11:32 AM
Look in to DC motor first. Then ask yourself how does power get between the various brush arms.
There is another way to transfer current, but flashover doesn't do the motor any good.
11/27/2013 12:03 AM
Mentioned clearly that power is fed normally to armature, interpole thro brush holders as armature circuit and seperately to field circuit in DC Motor.Motor works normally.But the reason for provision of short link between brusholders by a small crossection wire not known
Sadasivam
11/27/2013 3:14 AM
What - even after reading #1?
Register to Reply 7 comments
Andy Germany (2); J.SADASIVAM (2); PWSlack (2); TonyS (1)
