Previous in Forum: Heat Exchangers   Next in Forum: Secondary Super Heater Coil Minimum Temperature
How To Design A Filter ?
11/27/2013 12:18 AM
sorry for the terrible mistake
the specifications are as follow:
- the application is to filter the partially reacted polyethylene and wax that are carried out with the recycled ethylene gas from the low pressure wax seperator to the booster compressor in an LDPE plant
-the mass flow rate is 46 ton per hour
- the pressure is between 1.5 to 2 bar
-the pipe diameter is flexible to optimize the flow
-the temperature is between 40 and 60 Centigrade
again
What are the variables that I should focus on?
and
Is there a comprehensive source that I can go to?
Thanks
Pathfinder Tags: Filter design
Re: how to design a filter ?
11/27/2013 3:18 AM
It will be 1/3000 the size of the previous one.
Get a local Process Engineer engaged on this task without delay.
