I have a continuous improvement prototype project. Built a 17'X3' VAWT with a typical 10" dual rotor AFA 12 poles 9 coils. I am a little confused now how to approach increasing the size of the AFA. My goal is to run my pellet stove which draw about 100 watts below our average winter wind speed so in about 8 to 11 mph winds. Not unconceivable to my knowledge based on the size of the turbine. The power curve now is it starts to charge 24V bank in about 10 to 12 mph winds and hits maybe 12 to 24 watts in about 15 mph winds. Using a 16AWG stator it breaks fairly hard shorted out but not so much with an 18AWG stator. Both the stators perform fairly similarly otherwise. Of coarse the power curve is steeper for the 16 AWG so the 18 AWG is more consistent output. The 18 AWG stator warped with the motor on break in high winds. I am going to add a second 18 AWG stator to increase the size of the AFA. Am I limited to trial and error improvements or do you see a more educated approach to how one would size up motor size requirements based on what I have observed. The turbine having not stalled tells me it has sufficient torque that I have room to increase the motor size.
