Previous in Forum: Collare Warper Crotch Plate   Next in Forum: Space Heater Connection Size
NPSH for a Serial Configuration
11/29/2013 8:54 AM
Hi everyone,
I have this doubt.
How to calculate the available NSPH for a pump that is going to be place next to another pump (pumps in serial connection)?
Thanks in Advance
Re: NPSH for a serial configuration
11/29/2013 10:02 AM
http://www.mcnallyinstitute.com/11-html/11-12.html
if your second pump is very strong, you will have cavitation issues there, so be careful in calculations.
Re: NPSH for a Serial Configuration
11/29/2013 10:53 AM
Upstream or downstream?
11/29/2013 11:33 AM
downstream of the existing pump.
11/29/2013 12:56 PM
Do you know anything about pumps?
Like, maybe their specifications?
12/01/2013 9:16 PM
The current pump it is a part of the last effect of an evaporator (juice side) and it has two functions:
1. recirculate the juice to the top of the effect
2. send the juice to a residence tank before another process
So, as a part of a modification the destination of point 2 will change (more piping, more fittings). So I want to install an downstream pump in the piping that sends juice to the tank. I don't want to change the current pump because the recirculation rate of the evaporator would change.
The current pump delivers a head of 2.5 bar at 10 m3/hr (required flow to the tank).
11/30/2013 3:09 AM
Use of pumps in serial position means that the downstream pump is the booster for the upstream one. You should take care that the NPSHA of the second pump is well over the NPSHR, so you will have to calculate the system resistance between both pumps and deduct it from the operating pressure of the 1st pump.
The remaining pressure should be over NPSHR of the 2nd pump, assuming both pumps are the same type and size.
BR, Gert
11/30/2013 10:57 AM
It is an iterative calculation based upon the performance curves of each pump and the system characteristic curve. If all else fails, hire a Process Engineer to do the maths.
Register to Reply 7 comments
ChemistUSX (2); Gert Mengerink (1); LongintheTooth (1); lyn (2); PWSlack (1)
