I will be making a high power desulfator using 6 IRFB4110PBF power mosfets. The desulfator will send high current 80v pulses into the battery. I can drive one mosfet from a PWM pin on an AVR I have but how do you drive several in parallel? Also, will I need a massive diode after the mosfet group to prevent current from the battery going back into the circuit and damaging the mosfets?
