Previous in Forum: Max Sag on TL   Next in Forum: Corona Loss for 132 kV Single CKT Line.
Mechanical Design of Transmission Line
12/05/2013 11:40 PM
Hi,
Mechanical parameters are also important in the design of transmission lines. What all are to be determined. I think the following are sufficient.
1. Max sag (at 75oC, and no wind? , or considering wt of ice, conductor and wind?)
2. Max tension (assuming suitable factor of safety of 2.5 (IEC))
3. Stretched and unstretched length of transmission line (eg for everyday temp and max temp of 75oC).
4. Sag and tension under erection conditions from worst weather conditions.
Any others to be determined?
Regs,
sks
CR4 ADMIN - thread closed
This thread has been closed because it is a duplicate. Please add your comments to the original thread.
This discussion was "closed" on 12/06/2013 9:38 AM. No new comments are allowed.
Message from admins:
duplicate thread
Re: Mechanical Design of Transmission Line
12/05/2013 11:53 PM
Good Answers: 444
12/06/2013 12:02 AM
In reply to both posts:
Lyn is correct. Simply stating max sag isn't enough, you have to specify the operating conditions. Like everything else in electric power engineering, it's part of a system, and there are considerations that go beyond the electrical aspects.
There's max sag when the transmission line is being strung, when it's being operated under no, light, normal, and emergency loading conditions, under varying weather conditions, when crossing over highways, railway tracks, vegetation, different combinations of some or all of the above, and ultimately the point at which the line will have been stretched beyond its ability to return to normal when the overload is removed.
You pick the condition, there's a formula or a rule for it, and it's as much an art as it is a science.
Good Answers: 181
12/06/2013 9:01 AM
How many times have you been told "do your own homework!"
Register to Reply 3 comments
duplicate thread
lyn (1); RAMConsult (1); TonyS (1)
