Previous in Forum: Electric Furnace   Next in Forum: Rotor Current (Induction Motor)
11 comments
Transformer Neutral Earth Pit Problem.
12/06/2013 10:08 AM
Dear all
Today we face a problem in our 33/6.3/.415Kv Transformer.
Earth pit for Neutral solid grounding of secondary(.415KV) both Earth pit & its surroundings got too much heated,when we checked Neutral to Body earth voltage that is 230v & R-Y-E=415V WHILE B-E=0V.so that we take a cable & touches the neutral to another earth pit then a spark will come & after that everything is ok.mean Neutral to earth voltage is 0V.& also B-E=230V.
we still not understand what actually...is it neutral disconnection problem?
Good Answers: 445
Re: Transformer Neutral Earth Pit Problem.
12/06/2013 11:30 AM
If everything has "...got too much heated..." then it's time to find out why so much current is flowing. You may have a severely unbalanced system, a low-level earth fault somewhere, and/or are in need of additional earthing pits and a way to keep them wet enough to keep on "earthing" for you.
12/06/2013 1:11 PM
Your post is confusing. I will make the assumption that you have a wye connected secondary with the neutral point connected to your earth pit. The voltage between phases RB, RY or YB should be 415 volts. The voltage from R,B or Y to neutral/earth should be 230 volts. Neutral to E should be zero. In your post you say"B-E = 0 volts." The only way that could happen is if you had a delta connected secondary with B grounded. Your statement R-Y-E = 415 volts can not be right. What do you mean by "touching the neutral to another earth pit" ? You can have a difference in potential between earth pits. You may have sparking occur in this situation. Please add some additional information.
Good Answers: 181
12/06/2013 5:06 PM
Given the figures you state you've lost the neutral star point earth connection and now have a phase to earth fault. Is the neutral solidly bonded or via a NER? Failure of the NER followed by a phase to neutral will give the figures you quote.
As for getting sparks when you connected the two pits, I surprised you didn't get a big bang!
Good Answers: 42
12/07/2013 8:58 AM
I think the same as TonyS in the "first pit"case the neutral was not grounded but phase B was.
In the second case "pit no.2" a short-circuit occurred between phase B and the neutral through the Ground , the connection to ground of phase B burnt out and delivered phase B from its earth connection.
Julius
Good Answers: 170
12/07/2013 1:08 PM
Typical "Indian" way of problem solving?
12/08/2013 10:02 AM
Absolutely not
Good Answers: 170
12/09/2013 4:33 PM
"so that we take a cable & touches the neutral to another earth pit then a spark will come & after that everything is ok".
Then what? Rather than analysing the problem, you brag that you touch the neutral to another earth pit & gosh! spark will come????
Had it been a site with inflammable or explosive materials, what your 'spark' could have created?
Good Answers: 445
12/09/2013 11:13 PM
A well deserved Darwin Award....
12/10/2013 9:39 AM
As we think neutral is disconnected from its pit so we just connect one pit with another and a very little spark came just like we discharge a fan capacitor.
12/08/2013 2:05 PM
Do you mean that the ambient temperature got really high, the ground dried up and the earth pit resistance increased?
12/09/2013 1:04 PM
The solution is to isolate the installation from all sources of power on the basis of danger to life and property, and to hire a qualified HV Electrician to put things right. Wasting time on CR4 only increases the chances of hurting/killing someone. So do it now/this morning/immediately.
Register to Reply 11 comments
7anoter4 (1); electricalexpert65 (2); jack of all trades (1); lalit_nawada (2); PWSlack (1); RAMConsult (2); TonyS (1); wareagle (1)
