Previous in Forum: Transformer Neutral Earth Pit Problem.   Next in Forum: Discolered Breaker Terminals
10 comments
Rotor Current (Induction Motor)
12/06/2013 2:44 PM
I've found this equation:
where it is said that "Ir" is the current at the rotor (of an induction motor), and Ebr the maximum voltage (with a blocked rotor) and S is the Slip. I don't know what Xbr means??
Does someone recommend me a book or an internet article where this equation, and other like starting torque, is explained.
Thanks in advance
Good Answers: 445
Re: Rotor Current (Induction Motor)
12/06/2013 4:53 PM
Xbr is the reactance when the rotor is blocked, it's based upon one of the many ways of modeling an induction motor. It's a bit odd that you'd be interested in the rotor current since on most machines it can't be measured and is usually referred to in terms of the stator current. The exception is if you're modeling a wound rotor induction motor which does have the rotor winding brought out to a variable resistance via slip rings and cn therefore be measured..
12/06/2013 11:42 PM
Hi.
Text books: 1. Electrical machines by P S bimbra
2. Electrical machines by IJ Nagarath & kothari.
12/07/2013 11:40 AM
Dear Mr. hari520,
I want to supplement to your answer.
Electrical Book by B.L.THERAJA.
Also we can get much details from http://electrical-engineering-portal.com
DHAYANANDHAN.S
Good Answers: 170
12/07/2013 1:06 PM
Sir, do you know the famous pastime of IIT Electrical Engineering Students? Picking up mistakes in BLT.
Good Answers: 170
12/07/2013 1:05 PM
These books are only examination & syllabus oriented. They do not discuss the subject in-depth. A professional electrical engineer can point out millions of conceptual mistakes in such books.
Rather " A Theory of Alternating Current Machines" by M. G. Say would be the best to understand AC Machines.
12/08/2013 2:22 AM
Dear Mr.electricalexpert65,
Thanks for your response and I agree with your views.
Mistake/errors are there. The subject matter was dealt with in a broad manner. What I felt, from understanding point of view it will be OK.
Dhayanandhan.s
Good Answers: 42
12/07/2013 3:03 AM
This formula is correct one if we take into consideration the fact that both rotor resistance and reactance are strongly influenced by skin effect and are changing with rotor frequency-that means the slip. For protection setting calculation purpose there are some appreciations as following:
"The positive- and negative-sequence rotor resistances are
given by the linear functions of slip S:
R1 = (RM - RN )S+ RN
R2 = (RM - RN )(2 -S) + RN
where: RM is the rotor resistance at locked rotor
RN is the rotor resistance at rated speed "
See: From the Steinmetz Model to the Protection of High Inertia Drives by Stanley E. Zocholl Schweitzer Engineering Laboratories, Inc.
Julius
Good Answers: 137
12/07/2013 10:40 AM
How do you define slip S? Usually it's (synchronous speed - actual speed)/synchronous speed. But on that basis it = 100% with locked rotor. If the motor is then unlocked S falls as the motor accelerates, indicating rising IR, but in practice current falls as speed rises.
Good Answers: 445
12/07/2013 3:22 PM
CM, Correct, at standstill (blocked rotor) slip is 100%. Take a second look at the equation, slip appears in both the numerator and denominator, therefore as the motor accelerates, slip falls from 1.0 (100%) to around 0.03 (3%), and Ir does indeed fall.
Here's a link to a good slide presentation that shows the derivation (you'll have to do some algebra to get the same exact form) and a plot (pg. 8) of the rotor current as a function of both slip and speed.
Good Answers: 137
12/07/2013 7:28 PM
You're right, I hadn't spotted that. My mistake
Register to Reply 10 comments
7anoter4 (1); Codemaster (2); dhayanandhan (2); electricalexpert65 (2); hari520 (1); RAMConsult (2)
