Previous in Forum: Space X Finally Flies   Next in Forum: The Secretive Trans Pacific Partnership - Ask More Q's
11 comments
Good Answers: 117
Self Priming Pumps
12/07/2013 12:47 AM
Hi All...
I've been searching for a company that makes/sells self priming pumps capable of 50m3 per hour ± pumping slightly acidic flushing water ph of 4 (approx) maybe lower!
I can find hundreds of pump company's, the ones I've asked so far don't want to know.
Grunfos seems like a solution, but are as helpful as a flat battery in an electric toothbrush!
just a name/website will be very helpful.. Thanks y'all
Good Answers: 141
Re: Self priming pumps
12/07/2013 2:26 AM
Jabsco, Johnson, ITT corporation, The Weir Group PLC, KSB AG
Have also AC models, the first 3 have bronze bodies and rubber impellers.
What freq. and voltage?
Duty cycle?
Regards. D
Plenty of room here
Good Answers: 117
12/07/2013 2:33 AM
just the pump is required..... however if they have a 3ph 480volt 25HP motor then I'll take it!
many thanks for your quick reply! gonna check them out
Good Answers: 141
12/07/2013 2:40 AM
Are you sure about 50 m3 per hour? 25 HP seems very high to me.
There is also MONO (UK origin)
Plenty of room here
Good Answers: 117
12/07/2013 2:51 AM
yes 25hp is high.. but it's for use here in Oman.... and better to be to big than to small, taking into consideration the heat factor etc..
Good Answers: 21
12/07/2013 3:13 AM
If I were you I wouldn't write off Grundfos. They make good pumps and I found them very helpful but that was 10 years ago and maybe things have changed.
Good Answers: 117
12/07/2013 3:28 AM
yes normally I'd agree, but I'm in Oman.. different rules. No help whatsoever!
Good Answers: 48
Re: Self Priming Pumps
12/07/2013 6:17 PM
Hi Brich,
If you are looking for good self-primers for aggressive fluids, there never was anyone better than LaBour Pumps, both for handling aggressive fluids (corrosive and abrasive, superb range of materials) and for self-priming performance (I actually saw batter than 8.5m lift!). Unfortunately the UK outfit was swallowed up by Sterling process some years ago, and has effectively disappeared. You might still get the pumps from SIHI, but it will be no fun dealing with them, and they know very little.
You could try LaBour/Taber USA, if you pm me I might still have a contact there, and they might at least know more about the pumps than SIHI.
It might be best if I contact an old friend in the UK who used to deal with these pumps for many years, but also made his own self-primers and vertical pumps for many years. He knows them far better than the SIHI/LaBour guys, and also knows the petrochem industry better than most.
Let me know.
12/07/2013 9:55 PM
What discharge pressure? (~220gpm). If not too high, some plastic ones might work.
12/08/2013 2:17 AM
Give it a try at SPX Flow Technology Assen BV in The Netherlands and ask for selfpriming pumptype Freflow in Stainless Steel.
Good Answers: 153
12/08/2013 4:56 AM
Bredel Model 100 parastaltic hose pump. Suction lift 9.14m Capacity 52.9m³/hr. (also 78m³ and 108m³ versions available) Hoses available in Natural Rubber (+80°C, -20°C), CSM (+80°C, -10°C) & EDPM (+90°C, -10°C) any one of which will cope with your acid. Bredel is now part of Watson Marlow.
Good Answers: 117
12/08/2013 7:01 AM
many thanks to you and to every one who has responded....
love to stay and chat, but got a lot of pump companies to contact!!
Register to Reply 11 comments
brich (4); dvmdsc (2); Gert Mengerink (1); Holzfeller (1); jhhassociates (1); MACA (1); Tornado (1)
