Previous in Forum: Gate Valves   Next in Forum: Robot/Machine Accuracy
WPS Qualification with A 516 Gr60 & S355J2N
12/08/2013 2:50 AM
Is it possible to carry out WPS by welding together A 516 Gr60 & S355J2N.What will be acceptance criteria for mechanical test.ie A516 or S355J2N.
Re: WPS qualification with A 516 Gr60 & S355J2N
12/08/2013 6:21 AM
For general purpose, there is no problem to weld both these materials. (Eg: - For welder training or Equipment fabrication for personal usage).
However, there is some problem for preparing WPS for coded work.
The data you provided is only material of construction.. Could you provide following details,
1. This WPS for Pressure part welding OR Non pressure part welding OR Pressure part to Non pressure part welding?
2. Construction Code?
3. Welding Code?
Appreciate your feed back
12/10/2013 2:37 AM
Equipment is Treated water dump Caisson,Design pressure is 35 kg/cm2,Its a non coded stamped. Code Welding is Sec VIII div-1 and sec IX, and welding is for Shell (S355J2N) and Head is (A516 gr 60).WPS is for pressure parts.
12/10/2013 4:47 AM
Check page No 64 to 81 Here
I know only AWS D1.1,AWS D1.1, AWS D.1 and AWS D1.1, BS EN ISO 15614-1 and EN ISO 287-1
Hope this helps
Cook turned carpenter
Re: WPS Qualification with A 516 Gr60 & S355J2N
12/10/2013 5:24 AM
Anonymous Poster #2
12/10/2013 6:03 AM
If your welding codes are sec-viii and sec-ix, then acceptance shall be as follows,
