Previous in Forum: WPS Qualification with A 516 Gr60 & S355J2N   Next in Forum: Role of a Mechanical Engineer in a Cement Industry
Robot/Machine Accuracy
12/08/2013 7:58 PM
Hi friends, I search after examples or videos or names of robots or machines that work in a very accurate scale something like one millimeter of accuracy or better accuracy, so if you know about a robot or machine that work very accuracy so I will glad if you can write this in this thread.
User-tagged by 1 user
Re: accuracy
12/08/2013 8:08 PM
What is your name?
Re: accuracy
12/08/2013 8:12 PM
You don't know his name? This is obviously a friend (says so right at the outset), how could you possibly not know his name?
Re: accuracy
12/08/2013 8:23 PM
  1. Danish robot reduces cost, optimizes production at precision ...www.universal-robots.com/GB/Cases/Sky_Engineering.aspx‎
    Rising wages and the intricate management of the labour force have created a challenging work environment for a Singapore-based company, Sky Engineering.
  2. Precision robots on the cutting edge - Abb.uswww.abb.us/cawp/.../695c4d83ed2a8be0c12569f100319d0d.aspx‎
    Zurich, Switzerland, February 12, 2001 - ABB has developed a high-precision robotcontrol system for laser cutting which offers ten times more accuracy than ...
  3. KUKA Industrial Robots - High-accuracy Robotswww.kuka-robotics.com/en/products/...robots/.../high_accuracy_robots/‎
    Designed for high-precision specifications, HA series robots are particularly suitable for laser applications or the gauging of components. These robots feature ...
  4. 6 axis robot - SCARA robot - industrial robot - Robotics - SCARA and ...www.staubli.com/en/robotics/6-axis-scara-industrial-robot/‎
    Industrial robots, 6 axis robot, scara robots - Staubli robots for all industries and ...high speed, precision, resistance to all types of environments and, above all, ...
  5. High-precision robots available in kit form - EPFLactu.epfl.ch/news/high-precision-robots-available-in-kit-form/‎
    17.06.11 - A doctoral student from EPFL's Laboratory of Robotics Systems has developed a concept for modular industrial robots, based on the technology of ...
  6. [PDF]Calibration of Ultra-high-precision Robots Operating in ... - Infoscienceinfoscience.epfl.ch/record/166120/files/EPFL_TH5098.pdf‎
    by E LUBRANO - ‎2011 - ‎Cited by 4 - ‎Related articlesaccuracy for ultra-high-precision robots it is necessary to acquire a complete ... The 3 DOF ultra-high-precision parallel robot Agietron Micro-Nano was calibrated.
  7. Precision Adhesive Dispensing Robots | Henkel - Loctite® Equipmentequipment.loctite.com/catDisplay.cfm?...Precision%20Adhesive%20Disp...‎
    Loctite is the premier global manufacturer of adhesives, sealants, lubricants and dispensing and curing equipment. The adhesive technologies we offer are ...
  1. 7-Axis Humanoid Robot Arm‎Adwww.robai.com/‎
    With graphical software for tasking from a PC. Starting under $5K.
Searches related to precision robots
mitsubishi precision robots
melfa robots
1
6
7
8
9
10
Next
Re: accuracy
12/08/2013 8:35 PM
Nice selection, though most of those deal with precision. I'm not sure high accuracy is so much a quality to be found in a Robot/Machine....
Re: accuracy
12/08/2013 8:40 PM
It was the first thing that came up when I did what the OP should have done.
Re: Robot/Machine Accuracy
12/09/2013 5:00 AM
Look up "pick and place" machines.
12/09/2013 10:19 AM
Different machines for different applications.
The robot for placing components on PCB is vastly different from one doing welding on a vehicle production line. Robot for Ic die wiring is different again. Robot for automatic parts picking is different again. Nice to know the application, but others have posted some good specs. If you have a Robot with +- 1mm accuracy that can position with one ton of load it will be significantly different from one which postitons a one pound load.
LongintheTooth (1); lyn (3); Randall (1); truth is not a compromise (2)
