Previous in Forum: Hydraulic Elevator Problem   Next in Forum: Water Carry Over In Smoke Tube Boiler (Fire Tube Boiler)
10 comments
International Tow Truck Problems
12/13/2013 8:54 PM
Hi I'm I have a problem with my 01 International 4700 tow Truck was running fine i changed the glow plug solenoid trying to get glow plugs to work went to start truck nothing sprayed a little either i know not good for engine any how it ran i know my injectors are not firing tyred to pull codes but no light with key on i think maybe i fried my ECM any ideas How can i b sure if my ECM is working or not any help would be greatly appreciated.
Good Answers: 70
Re: t444e
12/13/2013 9:47 PM
Does your "Check Engine" light come on when you turn the key on? You might try a couple things first, (1) cleaning the fuel strainer at the fuel filter and changing the fuel filter. (2) change the engine oil. Have you connected a code reader to it? Does your "Check Engine" light come on when you turn the key on? Chances are, if it runs after squirting ether into it, the ECM is ok. There are other forums that talk about this, click Here
Re: t444e
12/13/2013 10:53 PM
Try the Diesel garage, they can probably help....
http://www.thedieselgarage.com/forums/showthread.php?t=109722
Re: t444e
12/14/2013 11:29 AM
No the check Engine light does not come on when i turn the key on nor does the wait to start come on with the key off the wait to start light has a dime glow like the battery was low but it is fully charged it might b as simple as a fuse able link or fuse i don't know about i checked fuses and double checked switched relays no change.
Good Answers: 70
Re: t444e
12/14/2013 1:51 PM
We don't know where your located, but being you have a towing service, do you have any connections with the repair shops you tow vehicles to or for? they might be better at helping you with this, at least they'll have it in front of them to work on it. Do you know someone else that has the same truck you can barrow their ECM to check your truck. Or click Here and see if anything will work for you.
Did you plug a code reader in and check for any hidden codes? Have you tried to "reset" or clear codes with a code reader? Old engine oil does not have the viscosity to operate the fuel injectors. A clogged fuel strainer and or fuel filter will not allow enough fuel to the engine.
If you are planning on fixing this yourself, I would highly recommend buying a repair manual with a good trouble shooting section that includes flow charts. Otherwise take it to a repair shop and plan on spending $$$
Re: International Tow Truck Problems
12/14/2013 11:02 PM
Some where you have an open in the electrical system. I would surmise that in changing the solenoid, you caused the problem. It ran before you changed the solenoid, so it should after you finished the job. Retrace you steps, did you remove the battery cable, you should have. if so, maybe a poor connection when the cable was replaced. If you didn't remove the cable, then maybe you shorted a cable when you disconnected the solenoid, blowing a fuse. If the dash doesn't light up, as normal on a startup, when trying to start then the computer is not getting power. Sometimes the manufactures put overcurrent devices in weird and wonderful places. If you can't find anything call a competent mechanic a little closer to home.
Good Answers: 70
12/14/2013 11:31 PM
They do have a big expensive fuse in line, I believe it's called an ECM
12/15/2013 7:03 AM
When the engine is warm disconnect the new solenoid tape the connections does it run properly? I think you may have wired it up wrong. Once my diesel tractor is warm I don't need glow plugs except to plug the holes in the block.
12/15/2013 9:25 AM
You don't mention why you changed the relay in the first place, please do.
ie you cause sparks?
Did you blow any fuses? Have you catually checked with a meter?
Was the relay "truly" compatible, or did it just happen to fit?
Have you tried putting the old relay back? What happened?
12/15/2013 10:59 AM
Internet auction sites (names withheld) are great for getting rid of problems like this. One simply lists the vehicle with a few photographs and an accurate description of the fault(s), then a few days later someone comes along with some money, swaps it for the vehicle, and takes the problem away.
12/16/2013 8:46 AM
Yea i think your right lol big expensive fuse i know i should have unhooked the batteries I do know better just always in a hurry not enough time to do it right the first time always enough time to fix my screw up Ive been looking for a ecm to borrow no luck yet we dont have a dealer near us miles city mt home of the world famous bucking horse sale. anyhow ive checked fuses double checked looked at wires i dont think a code reader would read code if check engine light wont come on im leaning towards the ecm going to order a used one today that come off a running truck to look at which i may have to any how i did put the old selinoid back on no change im shur it has to do with what i did when changing it ive changed them before with out problems and the selinoid wasent the problem i have power to all three leads just not the two that go to the selinoid so let the fun beginhopefully get ecm this week and get it going.
Register to Reply 10 comments
Andy Germany (1); bodyman (2); dj95401 (3); PWSlack (1); rhandwor (1); SolarEagle (1); vtbgiraud (1)
