Previous in Forum: Transformer Class of Insulation   Next in Forum: Extracting Angle of Phasor from Sampled Values of Phasor
13 comments
Induction Machine
12/16/2013 9:23 AM
I have a ABB make squirrel cage induction machine of 415V, 5HP, 1425 rpm, 7.8A.
Now, I want to do block rotor and no load test to get the equivalent circuit parameters.
I have doubt regarding to the tests whether in star connection or delta connection as it has all 6 stator terminals out. Also, 7.8 A current is line current for star connection or delta connection.
Can anyone please give some solution.
thanks in advance.
Good Answers: 445
Re: Induction Machine
12/16/2013 10:55 AM
Consult your class or lab notes for the proper procedure to follow. If you were absent or inattentive that day then Google is your friend.
12/16/2013 2:04 PM
It's all in good ol' British Standard 7671 - again <sigh>.
12/17/2013 12:47 AM
Check the name plate for connection,afterwards apply rated voltage & measure no load starting & running currents by an analog clamp-on meter & let us know the readings. Normally LRC is about 6 to 8 times FLC. Confirm from manufacturers by giving them model,frame size,serial number etc
pnaban
12/17/2013 1:15 AM
thanks for the response. I mailed the content to the manufacturers but they did not reply.
In the name plate, the connection is not mentioned.
name plate details: 5HP, 415 V, 7.5 A, 1425 rpm, Pf=0.83, Eff=0.85
The no load current (L-L) for delta connection is 3.8 A while same for the star connection is 0.9 A. As the no load current of induction machine is normally 30-50% of rated current, so it looks that machine is made to work in delta.
Comments!!
12/17/2013 2:22 AM
Then pick up the phone and use that instead. Time waits for no-one!
12/17/2013 2:32 AM
Can you measure no-load starting current too & inform us?.
pnaban
12/17/2013 1:25 PM
At the instant of switch-on, the motor is not rotating, and has no idea what it is connected to mechanically. So the no-load starting current is the same as the full load starting current.
As a rule-of-thumb, one usually takes 5 times the full load current as stated on the rating plate attached to the motor.
12/17/2013 10:10 PM
When power is switched on to any motor the current taken has several modes like inrush,starting,no-load,even FLC,LRC currents like synchronous generator under fault condition taking subtransient,transient & syn reactances/current. I have asked OP to measure & give no-load starting current or can somebody give recorded/measured values or graphs by datalogger/poweranalyser when an induction motor is switched on at noload & with load.
pnaban
12/20/2013 11:12 PM
Dear AAA65,for a 3hp 400V 5A delta motor noload starting current was 21A, give your reading
pnaban
12/17/2013 12:51 PM
1. Following would be the possible Nameplates for this Motor
a. 3.73 kW, 240 / 415 V, 50 Hz, D / Y, 13.03 / 7.53 A, P.F 0.81, Eff 0.85
b. 3.73 kW, 415 / 720 V, 50 Hz, D / Y , 7.53 / 4.3 A, P.F 0.81, Eff 0.85
Lets assume Nameplate 'a' i-e ( 3.73 kW, 415 / 720 V, 50 Hz, D / Y , 7.53 / 4.3 A)
2. When Motor is connected in Delta and 415 V are applied to it:
Name Plate: 3.73 kW, 415 , 50 Hz, D, 7.53
At No load Motor will consume 40 to 50 % of its rated Current i-e 3.1 to 3.76 A
3. When Motor is connected in Star and 415 V are applied to it:
Name plate : 3.73 kW, 720 V, 50 Hz, Y , 4.3 A
As applied Voltage is 415 V, Therefore Power and Current reduces by 1 /3.
Mechanical Power : 1.25 kW ( 1/3 of its Rated Power)
Full Load Current : 1.43 A ( 1/3 of its Rated Current)
At No load Motor will consume 40 to 50 % of its rated Current i-e 0.572 to 0.715 A.
For more information see the thread
http://cr4.globalspec.com/thread/81632
4. According to my opinion it is Delta Connected Motor at 415 V as calculation are matching with the actual reading i-e
Delta:
Actual Reading : 3.8 A
Calculated value: 3.1 to 3.76 A
Star:
Actual reading : 0.9 A
Calculated Value : 0.572 to 0.715 A
Good Answers: 116
12/20/2013 1:20 PM
Sensible fellow, AAA665!
You went and measured it!
Note the maker did not give a rated voltage (415V) which could not be applied direct to a winding without exceeding ratings.
Your professor, by giving you a motor with two windings per phase, gives more options for measurement...
You can connect the two windings of a phase in series and connect these pairs in star to the 415V supply. This gives 120V per winding versus 415V rated. This gives a low flux density and maximum inductance - closest to a sinusoidal current on which the simple theoretical models are based. Obviously, locked rotor and pull-out torque will be minimal compared to 415V per winding.
Delta connection of series windings gives 207.5V per winding. Star connection of paralleled phase windings gives 240V per winding.
With 415V delta, you can try opening one winding in a phase and find what it does to current no-load and full-load in each phase.
Theoretically, with series windings, star, this motor could be 1610/930V supply - if the insulation would take it!
12/17/2013 1:26 PM
Someone needs to explain why the no-load current is of any particular interest.
Good Answers: 445
12/17/2013 2:18 PM
It has the same importance as the no-load losses in a transformer, it gives the magnetizing branch impedance for the motor, plus the iron/no load losses for those people that like to keep their motors warm by running them with no mechanical load.
Then there are those charlatans who want to help you lower those losses using their magic boxes that somehow neutralize this current even though flipping the switch to "off" is a lot cheaper.
Register to Reply 13 comments
67model (1); AAA665 (1); Aghvel Niazi (1); pnaban (4); PWSlack (4); RAMConsult (2)
