Previous in Forum: DC Inductance   Next in Forum: Cooling Towers
8 comments
Starting Current Star/Delta Starter
11/14/2012 11:32 PM
A 400v 3 phase motor is started with a DOL starter.
When started the motor draws 90A and produces 200% full load torque.
Whats the starting current if the same motor is started with a star/delta starter?
i know the
i have to x the current by something but im sure
90 x ?? =
Re: starting current star/delta starter
11/14/2012 11:45 PM
30A. The starting torque will be correspondingly less, and the motor will take longer to attain full speed. (If it can actually start.)
11/14/2012 11:55 PM
That what im after but how did you get this answer? 90 x 0.33? where does 0.33 come from?
11/15/2012 12:03 AM
I'll have to recheck. I think it may be 1/√3 for starting current (~52A), and 1/3 starting torque.
11/15/2012 11:27 AM
I also agree with Mr Tornado i-e Starting current will be approximately 52 A. It is either 10 KW or 7.5 KW motor
Rewriting the Question
1.A motor 10 KW, 400 V, 50 Hz, D, 19 A, P.F 0.86, 1450 rpm, when connected in Delta configration takes starting current of 90 A.
How much starting current would it take if it is connected in Star Configuration and 400 V are applied to it
a).When Motor is Connected in Delta Configuration and 400 V are applied:
Starting Current in case of Delta Configuration : 90 A
During Starting Motor takes 473 % of its rated current : 90/19 = 4.736
Motor other Parameters
Mechanical Power : 10 KW
Full Load Current : 19 A
Motor Full Load Torque = 65.9 N.m
b).When Motor is Connected in Star Configuration and 400 V are applied:
Mechanical Power : 3.33 KW (Approximately 1/3 * 10 KW)
Full Load Current : 10.97 A (Approximately / 1.732)
Motor Full Load Torque = 21.966 N.m (Approximately 1/3 * 65.9)
c).From 400 V Delta configuration to 400 V Star Configuration:
Mechanical Power : Reduces from 10 KW to approximately 3.33 KW
Full Load Current : Reduces from 19 A to approximately 10.97 A
Motor Full Load Torque = Reduces from 65.9 N.m to approximately 21.966 N.m
d). Starting Current for 400 V Star Configuration :
When the motor in Delta Configration starting current was approximately 4.736 times the rated current (4.736 * 19 = 90 A)
Starting current for motor in Star configration for 400 V will be approximately 4.736 * 10.97 = 51.95 A
2. For 7.5 KW, 400 V, 50 Hz, D, 14.6 A, P.F 0.85, 1450 RPM
During Starting Motor takes 616 % of its rated current : 90/14.6 = 6.16
When Motor is connected in Star Configration Current will be : 8.429 A
So starting current for 7.5 KW in Case of Star Configuration: 8.429 * 6.16 = 51.92 A
http://cr4.globalspec.com/thread/54100#comment562035
11/15/2012 3:53 AM
It is the load that presents the torque to the motor. A motor consumes the same starting current whether it is unloaded, fully loaded, or any shade of grey in between.
11/15/2012 8:19 AM
motor will take 1/√3 times starting current in star as compared to delta
11/15/2012 8:36 AM
That bit is true.
Good Answers: 804
Re: Starting Current Star/Delta Starter
11/15/2012 9:58 AM
33% starting current, 33% starting torque. But on transition, there will be a current surge that can potentially be upwards of 2000% of FLC, albeit very briefly.
Register to Reply 8 comments
Aghvel Niazi (1); iftikhar129 (1); jonosoup (1); JRaef (1); PWSlack (2); Tornado (2)
