Previous in Forum: Toyota Sienna CE - Manual Sliding Doors Won't Open   Next in Forum: Car Problems
14 comments
Traction Assist
12/17/2013 1:08 PM
If this has been discussed before, then forget this question. I searched and didn't find an answer on CR4.
When I had a nice rear wheel drive car I had a traction assist that locked the rear differential. I could go up the 20% grade hill on the township road to my house even in several inches of snow.
Now with my current front wheel drive, if I leave the car in "traction assist" the motor is shut down to idle by about the mid point of the hill and I am forced to back down the hill. Turn it off, and up I go.
How can the automotive engineers call this "traction assist"?
Re: Traction Assist
12/17/2013 1:24 PM
Not enough information.
I'd say that you have a problem with your ABS, maybe.
Re: Traction Assist
12/17/2013 1:34 PM
The way it functions, and I understand this is proper, is it applies a brake on the wheel that is spinning and if both are, it kills RPM to try to limit wheel spin. So when you need power the most, it is not there. Stomp on the go pedal and the rpm's just drop. I asked how to defeat this here in 2010, when the car was new, and was told about the switch on the dash to defeat the so called "traction assist" and was assured then that this was how it operates. Right now we've had 2 weeks of "lake effects" so I am getting a bit frustrated by the lack of a real traction assist.
Lyn - I thought you were and Electrical and Instrument man? Cars too?
Re: Traction Assist
12/17/2013 2:08 PM
Not me. I'm not "the man" for anything.
BTW, I'd much rather have the old style locking differential.
You might try these↓
How to disable Traction Control (TC) and Vehicle Stability Control ...
1) warm up the engine fully.
2) turn off the engine.
3) the side brake needs to be released.
4) press and hold the brake and start the engine.
5) while holding the brake, pull the side brake and let go of the brake.
6) press the brake 2 or more times and hold the brake.
7) while holding the brake, release and pull the side brake 2 or more times and hold the side brake.
8) while holding the side brake, press the brake 2 times.
9) TC and VSC lights should turn on.
If you can't turn the TC and VSC back on by pressing the buttons, then it worked. You'll need to turn off the engine to turn TC and VSC back on.
Note: I only tried this on MT. I'm not sure if it works on AT.
Or: How to Disable Traction Control | eHow
Re: Traction Assist
12/17/2013 1:26 PM
You could try backing up the hill....
Re: Traction Assist
12/17/2013 3:17 PM
....or you could just strap on a set of chains.....$16
Good Answers: 444
Re: Traction Assist
12/17/2013 2:45 PM
The engineers are directed by the marketeers to do so or fear being ostricized, that's how.
Get yourself a WJ series Jeep, totally mechanical AWD systems, no Big Brother telling you when you're pressing the accelerator too hard, just the laws of physics to guide you.
Re: Traction Assist
12/17/2013 2:58 PM
I figure it has something to do with going over rpm and destroying the engine while under warranty, but my son who is a car mechanic at a major brand dealership tells me they don't really need the protection as they know what you've done anymore - they record it.
All I really need, and I've done this in past winters, is put on a set of studded winter treads and stay out of "traction assist". But what a pain changing tires twice a year. Can't afford 2 sets of wheels with the pressure sensors they have now.
Good Answers: 444
Re: Traction Assist
12/17/2013 3:48 PM
Most modern engines have rev limiters programmed into the ECU, you couldn't push it to destruction even if you tried. And don't forget that nearly 20 million vehicles have "hidden" event recorders anyway. As far as the rims go, maybe you could find a pair off a wreck that has the right TPMS.
Re: Traction Assist
12/17/2013 5:48 PM
How good do you think those RPM limiters are on a sudden increase as you get with a full throttle and spinning wheels on ice? I've seen the after market ones on a drag race engine fail to limit when tires break loose in an unintended event or a drive shaft goes mid track. In a burn out (intended event) you want them to break loose, but the driver is still controlling the RPM a bit. At least I never mashed full throttle for an extended time - I always backed off the gas when they started to slip. I bumped the limiter just sporadically.
If not engine damage control then my question is still unanswered - why do install this system they call "traction assist"? It seems to be anything but.
Re: Traction Assist
12/17/2013 3:33 PM
The skid control on my JK Wrangler is crap. If I'm off-road and forget to disable it...well, that ditch had it coming.
After disabling it and some 4LO romping I cleared out the ditch for spring thaw. I shouldn't have been in the ditch to begin with but lack of power due to the "assist" contributed to the sideways slide down a mountain 4-by trail caked in snow and ice.
Scared the Hell out of the Subaru crowd heading up for cross country!
common knowledge...less common than common sense
Good Answers: 25
Re: Traction Assist
12/17/2013 5:53 PM
I have the exact same problem with my driveway.
The traction control seems to be designed for taking off from a stop on semi-slippery roads. It will keep an inexperienced driver from overpowering his/her tires when starting out on a flat slippery surface but it is worthless in any kind of off road condition.
Can you imagine dirt track racing where you couldn't spin the tires?
Troy
Re: Traction Assist
12/17/2013 7:08 PM
I want to know how many novices go to the drag strip with their new car to run street stock and get to the burn out box with the traction assist on and find they can't do a burn out. I walked away 13 years ago and haven't gone back, so I don't know. Must be really interesting watching that. They pull in - mash the throttle - and the car just blips the tires and dies out.
Re: Traction Assist
12/18/2013 1:36 AM
Find the traction button and turn it off. Same with pulling out the fuse for the ABS.
I want full control of what I am driving, not some stupid computer telling me what I need to do. Like Lyn, been driving for what? 500,000 - 700,000 miles in my life yet? 12 cars all over 200,000 miles. I never figured the total. Only had to deal with ABS and traction assist this past year. I pulled the fuses on both.
"Real Bass Players" do not use picks
Re: Traction Assist
12/18/2013 8:52 AM
You know what is really scary about the computer control - go into a corner a bit too fast some time and start to skid a bit - easy to control - right? Not with the computer control - it locks up a brake and shoves you directly at the other lane. (I know - I have a 90 degree turn at the top of that hill I am trying to climb and on the way down I am on the inside and there is gravel at times on that road right in the middle of the corner) Or drop a wheel off the inside onto the gravel berm for added traction and again the brakes come on and the engine power is cut - just what you don't want.
I think the automotive engineers have actually created a dangerous car with the computer control.
Register to Reply 14 comments
Jimh77 (1); lyn (2); Phys (5); RAMConsult (2); SolarEagle (2); The.Tinkerer (1); Troy36 (1)
