Previous in Forum: Traction Assist   Next in Forum: Stop-Start Automotive Technology
16 comments
Car Problems
12/17/2013 4:04 PM
I own a 2001 Chevy Cavalier and it starts at times and runs great for awhile, then it won't start..the motor rolls over but won't start..you can go out maybe 3 or 4 days later and it starts right up..What would be causing this problem?
Re: car problems
12/17/2013 4:07 PM
The starting part or the not starting part......?
Seriously though I would change the ignition switch and spark plugs....
Re: car problems
12/17/2013 4:11 PM
  • One cause might be the absence of a Google search on the hundreds of Chevy Cavalier problem-solving websites and a review of them in pursuit of a solution.
  • Another cause might be the absence of a listing on an internet auction site (name withheld) that might cause someone to come along in a few days with some money, swap it for the car, and take the problem away.
  • A third cause might be an unwillingness to have the thing towed to the local breakers to have the problem recycled.
Re: car problems
12/17/2013 4:15 PM
the fuel pump was tested and the electrical has been tested with nothing wrong with either..
Re: car problems
12/17/2013 4:16 PM
That won't get it recycled, though...
Re: car problems
12/17/2013 5:57 PM
I can confirm the pump is fine...
Re: car problems
12/17/2013 4:49 PM
Days later sounds like water fouling the ignition. a few days the water dries out and you get to run again.
OR NOT.
Re: car problems
12/17/2013 5:44 PM
water problem is what we thought also
Re: car problems
12/17/2013 8:25 PM
its not water. its the fantastic electronic design of the ignition system. these cars are EXTREMELY problematic. I hate to see people blow money trying to salvage a poor design. If I had a quick fix I'd offer it. I honestly don't think you can chase this gremlin down yourself. I suggest using a competent mechanic with experience working on these engineering marvels.....best of luck and keep the AAA membership up to date
Re: Car Problems
12/17/2013 5:29 PM
My first choice would be to bring this vehicle to a trusted mechanic. They will be able to test the fuel and spark system of this vehicle to identify what is intermittently failing. Most importantly they will be able to look at the failure codes stored in the ECU.
My next choice would be purchase a code reader or shop manual for this vehicle so I could test these systems myself. If anything baffled me I would consult with a Chevrolet specific forum.
Good Luck
Re: Car Problems
12/17/2013 5:53 PM
Leta, leta, leta,
You are wasting your time here.
None of us own a Cavalier, and wouldn't admit it even if we did.
There are a few bona fide mechanic/members but they can't read your mind and can only give you a list of POSSIBLE causes for the phantom gremlin.
If you don't want to take it to a mechanic, go to some of the forums I have listed below.
You have a demon. When the car's running, nobody will find anything wrong.
Cavalier - Chevrolet Forum - Chevy Enthusiasts Forums
Chevy Cavalier Forum - Chevy Forums
CavFanatic Forums
Google "Cavalier forums" for more torture.
Good luck.
Good Answers: 70
Re: Car Problems
12/18/2013 4:42 AM
Let me consult my Crystal ball. Oh yes! I can see it clearly now and ..... it's saying " Pick n Pull" will give about $250.00 running or not.
This comes with the normal disclaimers, We do not endorse any particular company and can only suggest where to look. And subject to change without notice, etc. etc. ....
Could be a number of different things, water in the fuel, dirty fuel pick up strainer, faulty fuel pump, ignition coils, ECM, over heating solenoids, bad cam or crank senor, etc. take your pick. if your bent on fixing this your self, as mention before, you'll need both OBD II CAN reader and a good repair manual that has comprehensive trouble-shooting flow chats
Re: Car Problems
12/18/2013 5:22 AM
C.A.V.A.L.I.E.R.
Causes All Very Annoying Largely Internal Expensive Repairs
C.H.E.V.Y.
Causes Heavy Expenses Virtually Yearly
Re: Car Problems
12/18/2013 7:32 AM
Advance Auto and Auto Zone will pull the computer codes free. Get this done and post the codes.
Re: Car Problems
12/18/2013 11:15 AM
If I recall from the four or five dozen threads on this issue, it has to do with the <snicker> theft deterrent system. It will randomly decide it thinks you are trying to steal it and immobilizes the car. It will take some serious digging to find the intermittent cause of this feature.
Re: Car Problems
12/18/2013 11:18 AM
Re: Car Problems
12/18/2013 11:21 AM
You da man.
Register to Reply 16 comments
Andy Germany (1); Brave Sir Robin (2); dj95401 (1); Fredski (2); Leta (2); LongintheTooth (1); lyn (2); PWSlack (2); redfred (1); rhandwor (1); SolarEagle (1)
