Previous in Forum: Smart Phone Wired to External Power Supply Questions   Next in Forum: Tablet Specs & Preferences
Pump Control Panel
12/19/2013 2:18 AM
Hi does anybody know of its at all possible to change 5x 24volt signal to 12 volts .
Re: Pump control panel
12/19/2013 4:24 AM
What is a "5x 24volt signal"?
Good Answers: 104
12/19/2013 9:51 AM
Yeah. You know - 5 x 24volt = 120volts
12/19/2013 5:18 AM
5x voltage regulators or voltage dividers?
More info needed as to the present signal versus desired signal.
Good Answers: 116
Re: Pump Control Panel
12/23/2013 6:32 AM
For each of the 5 signals at 24 volts, Use a resistance potentiometer with two equal value resistors R, tight tolerance.
Assumed conditions :-
24 volt source has low resistance compared to R, < R/100.
"12 volt" load has high resistance > 100R
Error of ~1.5% in reduction ratio compared to 2 to 1 is OK.
Do you mean logic signals (on/off) or analog signals e.g. process temperature??
Register to Reply 4 comments
67model (1); bigg (1); JohnDG (1); Tornado (1)
