Previous in Forum: Rubber Blocks Cutting   Next in Forum: Bearing Technical Information
Hardness of Material
12/24/2013 1:05 AM
Dear Sir's
How to test the hardness of materails.
Re: Hardness of material
12/24/2013 1:18 AM
Please Google on Rockwell and Brinell testing. These methods consist of pressing a shape into the material to be tested, and then measuring the diameter of the resulting indentation.
12/24/2013 1:22 AM
With a Hardness tester! What material would we have to take into consideration to answer your question?
12/24/2013 1:25 AM
What material? As everyone knows, the angle of the dangle is proportional to the heat of the meat, and also to the hardness of the lardness. From there, just work the arithmetic forward or backward as needed.
Re: Hardness of Material
12/24/2013 8:48 AM
The same way you replace bearings. Hire someone who can see what they're doing.
12/24/2013 9:19 AM
use the Rockwell scale and test
Anonymous Poster (1); Fredski (1); IdeaSmith (1); lyn (1); Tornado (1)
