Previous in Forum: Should I Enroll For a MEP Course?   Next in Forum: ME or MBA
Job Change from Power Plant & Industrial Design to Oil and Gas Electrical Design
12/24/2013 5:54 AM
Hi All,
I have 10 years experience in electrical design for power plant and industrial power distribution.can I get job in OIL and GAS field as a design engineer,kindly suggest.
Thanks in advance
Re: Job Change from Power Plant & Industrial Design to Oil and Gas Electrical Design
12/24/2013 8:28 AM
Based on the level, and quality, of information you provide here, probably not.
Mechanical Design Engineer Oilfield Jobs, Employment | Indeed.com
Oilfield Engineering Jobs on CareerBuilder.com
12/24/2013 11:29 AM
Does it mean Power plant and Oil&gas industry follow bit different electrical engineering principles?
12/25/2013 12:43 AM
not like that but recruiting companies are prefering candidates who gave prior experience in OIL and GAS
12/24/2013 11:43 PM
Hi Reddy, Shifting to oil and gas should not be a problem if it clicks. For instance I was in Metals and mining division (steel industry mainly), and have recently moved into oil and gas sector. To hive you a bit more confidence, I too am an electrical design engineer. Keep on trying and best of luck.
12/25/2013 12:48 AM
Thanks for your reply.
Good Answers: 25
12/25/2013 5:23 AM
You have long experience in power plants and industrial power distribution industry. Why to change to oil and gas industry?. It will be mostly off shore job. Why not to continue in your present job?. Is it boring?. There are many power plants projects lined up in India. There will be more demand for engineers like you.Many of these will be in private sectors so better prospects.Well decision is yours. I will rather suggest that you should advance your qualifications by doing management course along with your present job.
Good Answers: 117
12/25/2013 8:29 AM
Why waste ten years experience?
Stay in your field and expand your knowledge base. Become a "key man".
Register to Reply 7 comments
Anonymous Poster (1); gskreddy82 (2); kolokol (1); lyn (1); suresh sharma (1); Yusef1 (1)
