Previous in Forum: Grouting Cement   Next in Forum: Acoustic Engineering
22 comments
Milling Lumber--Green or Dry?
12/26/2013 5:43 PM
I am bringing some pine and red oak logs to a sawyer for milling. Some people have told me that band sawing logs into lumber should be done when the logs are green, within a couple of weeks of felling the trees. Some have said that it is better to cut the logs into lumber after it has had time to dry a couple of months. Some have said that it doesn't matter.
In my experience, I have found that when chain-sawing wood, the wood is much easier to cut when the wood is green---the same for cutting green or seasoned wood on my table saw. I have never milled logs into lumber with a band-saw mill. I would think that cutting seasoned logs, even just a couple of months drying time, would be harder on the band saw blade and the mill motor. Any opinions?
Thanks,
Don
The only people who don't make mistakes are those who don't try.
Re: Milling lumber--Green or dry?
12/26/2013 6:04 PM
They might not still be green, but logs are often kept wet, in millponds or by sprinkler systems.
12/26/2013 6:17 PM
You haven't told us when the logs were cut. (Felled, if you are a stickler) That matters.
Mill them. Period. Waiting won't buy you much. And it'll take forever to dry.
Saw it.
Stack it off the ground, with plenty of support and room for ventilation. I'd say an inch space from all surfaces is minimum.
Dry till the moisture content is below about 15% if used outside, about 10% if used indoors.
It WILL warp. That's why you leave it oversize and plane it.
Good Luck!
12/26/2013 6:20 PM
Hard woods should be kept wet, yards in mills usually have sprinkler systems in their lots. In soft woods green pine, the biggest thing you have is the pitch. The hard woods, such as Ash, if you let them dry out. There is a lot of internal stress, with the end of the logs being dried out, that will pinch the blade (even with a splitter) when you saw them
Or it will pinch the splitter tight where you have to saw off part of the board........ A lot of waste.
And if it's one of those one man band saw mills... It will be a struggle.
12/26/2013 7:26 PM
Thanks for the recommendations and questions. The trees were felled about 5 weeks ago. I also have another 5 southern pines (loblolly and short leaf), about 80 ft tall and 12" to 20" diameter at the butt, that I will be felling and taking to the miller soon. The local miller said he will split the sawn lumber with me, with a little chipped in for blades. I think that is a reasonable deal. The hard part is getting the logs on the trailer!
I have been delaying cutting the trees until the winter to let the sap fall. I have read that doing so slightly decreases the weight of the logs and, more importantly, decreases the bluing (from mildew) that occurs in the pine. It is also a lot easier for me to work outside in the winter in south Louisiana than the summer!
Thanks,
Don
12/27/2013 7:40 AM
Yellow or Jack pine has stress in them, white pine are easier to cut. (These are usually what the CCC planted in the 30's.
Normally, as least we do, we'll log in the winter and cut them in the spring. But then again, we're in the northern states.
The split is not that bad a deal, but with 12" at the trunk........ that's not very big., but you'll still get material.
Also as long as you didn't get the trees in your back yard or a fence line........ where there'll be nails or wire in them
Good Answers: 88
12/26/2013 11:21 PM
It is easier on your tools to process wood when cut green, BUT problem is dimensions WILL change while drying, i.e. will shrink. Even worse, they will NOT shrink symmetrically on all axes, it depends on grain orientation and distance from center of the log core, and of course not all tree types are the same. So your choice is about how demanding is your application on final dimension accuracy. S.M.
Good Answers: 70
12/27/2013 2:54 AM
You should be asking your sawyer this question, being its his equipment and he has the experience with his equipment. Green is easier on the equipment and the logs have less tendency to split due to drying out. I preferred my band saw over a circular blade, less waste, saw dust and noise
12/27/2013 6:25 AM
Actually, I did ask the sawyer about any difference in cutting green or seasoned logs and he said it did not matter. But, he seems to be in the minority with that opinion. Almost everyone else tells me that milling green logs is easier cutting and less wear on the blades and machinery. It doesn't matter a lot to me except I will be sharing in the costs of blades, upon his request. Maybe that is why he made the request......because he goes through more blades due to cutting drier logs??? With me supplying the logs and he doing the milling, we agreed to divide the lumber 50/50.
We will be using the 2 X 6X 12ft lumber to frame my son's 34' X 40' pole barn garage/workshop. He wants to use the 2 X's for studs between the poles. I think it will be fine to stack and stick the pine lumber for a couple of dry winter months prior to framing.
Thanks,
Don
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Re: Milling Lumber--Green or Dry?
12/27/2013 11:30 PM
Cutting the logs green allows you to control splitting. If the logs are drying, they have either begun to split or are building stresses that will lead to splitting. So saw your logs as close to green as possible. It just happens that wood is easier to cut when green.
Once the log is split, this is just another defect in the log that the sawyer has to deal with. It will test the skills of your sawyer, although with your payment arrangement he doesn't really care to maximize the recovery. If you paid him by the volume of usable lumber he milled, he might take more care to saw each log. At least, see if you can pin him down on the volume of lumber he expects out of your logs.
If you are talking about simple saw wear, we found that denser wood caused more tooth wear. For example, Pine doesn't wear the saws as fast as denser Douglas fir. Some of the hardwoods, such as your Oak will probably wear the saws quite a bit faster than the pine. It's a heck of a lot denser.
There is quite a bit of science behind tooth wear and wood cutting. For example, the guys who mill cedar big time will generally use stellite saw tips rather than the more-standard carbide tips that we see on saw blades. It turns out that the chemicals in the cedar will eat the edge off of carbide teeth very quickly but stellite stands up a lot longer.
Doesn't your guy have a band blade sharpener? He should be able to get a blade to last a long time!
I'm not sure you need to care about the extra load on the mill motor. The sawyer has to control his cutting speed to not overload the motor.
Summary: saw the logs right away for the best recovery. Your sawyer doesn't care how dry the logs are because he isn't supplying the wood. (You essentially pay for the waste.) Expect more saw wear in the dense Oak wood. Don't give a rats butt about working the heck out of the saw motor. That's your sawyers problem.
Hope this helps,
Jon.
Good Answers: 70
12/28/2013 1:03 AM
Jon, you brought up my next question for the OP, "Doesn't your guy have a band blade sharpener?" And if he does, does he know how to properly use it? Dull blades will cause a lot of hearts-aches for both operator and equipment.
12/28/2013 2:18 AM
I have been in the sawmill business for over 30 years
The issues you have all guessed at are not so complicated.
It is best to cut wood immediately in a perfect world but most often it is impractical.
It really depends more on sensitive species like maple if your looking to produce fine quality finish lumber .Pine can stain in as little as two weeks in hot weather .
Wood does cut easier when it is fresh mainly because it is full of moisture but it can be sawn even years later without many downsides as long as the end product is a barn or garage . The type of woods the original questions came from generally have little value as finish woods.
The deal made is fair and few people work for a share these days and the insinuation the guy is trying to cheat the man by delaying cutting are offensive and based on nothing but bad will.
If the guy gets a structure out of his logs it is a good ,fair,decent transaction stop trying to ruin a last vestige of human decency buy over analyzing an old school transaction.
Saw miller's are some of the most honest men you will ever meet ,my advise is work with the man ,do your part and keep the logs as clean as possible and if they do get dirty wash off or brush away all dirt and rocks and look for metal.(these are the culprits not dry wood that eats up blades,that's why it's fair to pay for blades if you bring dirty logs )
I good trick is to use a tree to winch or pulley the logs up and drive under,to get them on a truck or better a trailer for delivery.
You might find a local logging truck and offer him $100 and do it right and save everyone's back,I do it often .
I'm sure it will work out and you will have a friend for life ....best of luck.
Lighten up
12/28/2013 3:15 AM
I, too, have been in the business for more than 30 years as an engineer in the sawmill game.
However, I think we may have been in vastly different sawmill environments. It sounds like you are from the hardwood side of milling, where I have spent my time in the softwoods of BC, Canada. Where we convert a 20" log to a river of 2" lumber in about 2 seconds per 16' average log. 12,000 logs per shift.
I don't think hardwood mills have the same high volume focus.
The epidemic of bug kill here caused mills to have to operate on dead standing trees so old the bark was falling off. Lumber recovery fell way off with the dry split logs.
I guess in LA the stain issue can be a problem. Even if the lumber is stickered or dry piled the weather probably won't allow it to dry fast enough to prevent stain? A heated dry kiln is probably out of the question for the small amount of lumber in discussion.
The OP deserves to know about the possibilities of how his deal can be skewed if he does not know some of the details to watch out for. Not negative, just stating some facts.
I hope he ends up with a good, fair deal and does make a friend.
Jon.
12/28/2013 9:55 AM
It's interesting to know, what type of mill this is, I can only speculate with the low number of logs, that this bandsaw mill is a smaller mill, and possible one of the one man mills. Where it is more labor intensive.
12/28/2013 12:26 PM
I run a full automatic circle mill in New England mainly sawing white pine and red oak
the variables are the same ,if a big mill was so gracious to handle a couple of logs from a neighbor good for them ,most likely it's a manually operated band mill that a guy does in his spare time.Either way the conversation had gone from being informative to accusatory ( I was not singling anyone out )as it generally does on this forum .I rarely participate as I get tired of a bunch of washed out propeller heads probing for an opportunity to attack someone for a spelling error or god forbid a new idea .
I remember when I proposed the transfer of electricity without wires I got a taste of what Tesla must have experienced .Then shortly after MIT revealed significant break through's in exactly what I proposed .
I try to take a positive view of all ideas ,our country would be in the stone age if nay sayers had the loudest voice .
Lighten up
12/28/2013 1:15 PM
Traditional,
Your comment on naysayers is a mouthful! I have seen this full bore since I've worked with both sawmillers and pulpmillers. In the sawmill, if something doesn't work very well, the attitude is, "what can we do to fix it" and jump on doing the fix, even if it takes several tries. In the pulpmill, its "Fz**ing piece of junk. Toss it out". Trying to fix is a long drawn out and painful process.
I called this comparison of cultures a "sawmillers: "can do" attitude, pulpmillers: "can't do" attitude".
No wonder all the new pulpmills in the world are happening everywhere but North America.
Jon.
12/28/2013 2:07 PM
Good idea about winching the logs up and pulling under the log. My son came up with the same idea but we didn't have a convenient tree to use. We used our towable backhoe to lift the logs on the back of the trailer and then we used a 4 wheeler winch to pull the logs the rest of the way. It worked pretty good. I have several other big pines that I will cut soon. I am considering installing a hinged frame (inverted U-shape) midship on the trailer that I can attach a cable to. The cable would run to a winch at the front and to the log in the rear. As the cable is pulled, the frame rises, provides lift and pulls the log up and onto the trailer. I think it'll work OK and it is something I can do by myself.
Thanks,
Don
12/28/2013 4:03 AM
Get your band saws to be stellitte tipped,then your problems are solved,cutting wet or dry.
12/28/2013 5:18 AM
I only saw smallish stuff so I have limited knowledge... but IMO.
It's swings and roundabouts. A few months isn't going to make much difference to a log!
It's more important with some woods like Oak which is a joy to work green but hard as nails once fully seasoned... but like I said your logs won't be seasoned in 2 months!
There is no way you can second guess how the wood will move twist, shrink or split. Just rough it out well oversize. Season it for a year or so then get it cut to finished size.
That depends on the final use... if it's just fence posts then go for it, 'cos no one cares about the finish or exact dimension (well except for some daft city slicker garden design consultant with more money than sense, in which case you tell him they are authentic "rustic" and quadruple the price)
12/28/2013 1:51 PM
I do think the 50/50 sharing of lumber is a good deal. And, I am looking forward to meeting the sawyer; I spoke with him on the phone and he sounds like a nice, honest guy.
I told my son I thought that after the lumber dries for about 2 months (he won't be ready to install them until then) we can probably put in the studs with some blocking and, even though the wood 2" X 6" X 12' studs will still be on the green side, they should be OK. Of course, we will stack them with stickers and provide ventilation.
We are also sending the sawyer a couple of 8" sycamore logs. I am anxious to see the grain and how it dries; I hope to be able to make some furniture and picture frames with it. Unlike the pine, I will probably have to air dry the sycamore about a year/inch thickness. There is a lot of moisture in it!
12/28/2013 3:17 PM
There are a lot of different types of trees within the two basic characteristic categories, hardwood and softwood, and softwoods are not neccessarily soft, nor hardwoods, hard. Balsa is a hardwood.
Each of these types of wood will have a different milling characteristic and affect the blades accordingly. Some will be tough on the blades and require special blade tips, others will cut like butter. Some timbers when cut when dry, will require a lubricant at the blade/timber interface. Sometimes diesel is used. Whichever the type, or state of the timber, the cutting should not be a problem. Incidentally, timbers with a high silicon content will cause blade problems, whether green or dry.
Should you cut green or dry?
To leave the log until it is dry, can result in sap-stain in some species (and possible rot pockets). Years ago, after a large storm, windblow pinus radiata timber was left for months before extraction from the forest, After exporting it to Japan, the logs were nick-named blue-pine because of the sap-stain colour. It will also take a long time for the log to dry out.
Milling soon after logging, gives two benefits, one being that you can control the drying, and the other is that you can control the distortion that can occur as the timber dries.
All timbers will have some stress built up in the growing tree and when milled, these stresses will result in warping and bending. Suitable stacking (and sometimes weights on the tops of the stacks) will control this.
The method of stacking, will also control the rate of drying. Some timbers require a slow drying rate so that the internal stresses (sometimes referred to as "honey-combing") are kept to a minimum during the process. Others can be allowed to dry as fast as possible. Stacked, milled timber will dry a LOT faster than in log form.
These comments relate to both air drying and to kiln drying.
12/28/2013 7:56 PM
v
One further clarification
It is best to build with green lumber ...really
In the days of post and beam all structures were built green
This was for several reasons first green wood is easier to work ,second there was no time for the luxury of dried lumber ,third buy using wet wood as it dried it would lock the structure together as it dried .
Board and batten works because the inevitable gap that is left by using wet wood is covered by the batten.
It is best to simply build with the wood as soon as it comes off the mill no need to sticker unless you plan on making finish wood.If you stack dimensional lumber it will bend and warp and not work as well.
If you do need to wait to begin your project it's ok just expect some degrade a good trick is to bind the piles together with metal strapping to hold them from movement or just dead stack with no air gaps which is best done in cold temperatures to avoid mold and staining .
On your finish woods stack on a level area put stickers at 2 ft intervals make sure they line up for best results .The ends should be coated with anything from a wax to oil to prevent cracks ,we cut all lumber with 6" of trim to allow for degrade, cover with what ever you have tin , tarp,or old plywood .I get old lumber covers from the local lumber yard they through away.
With the beach remember the stickers should be dry white hardwood or they will cause bad stains and ruin your nice wood .
Thanks for the positive responses to my critical remarks peace brothers
Lighten up
Engineering Fields - Construction Engineering - New Member United States - Member - New Member Hobbies - Hunting - New Member
12/31/2013 6:21 AM
Sawing the logs while green is the best while keeping them clean from dirt sand and stones will also help on the sawing. One thing I have yet to see on this thread is once they are stickered and set to dry take and make sure they don't get direct sunlight this will increase the chance of warping and also coat the ends of each plank and up the sides about 2 inches this keeps the ends from cracking and checking. After growing up in a sawmill family I have seen first hand what happens when you don't coat the ends you sometimes lose a lot of lumber this way. coating the ends allows the wood to through the sides and not check and crack through the ends. we used to use a 50/50 mix of beeswax and linseed oil which worked pretty well, there are also products out on the market like (ANCHOR SEAL)
Most problems have simple low tech solutions
Register to Reply 22 comments
babasiga (1); Common cents (1); dj95401 (2); Don in LA (4); garyasta (1); lyn (1); phoenix911 (3); sawmilleng (3); SimpleMind (1); Tornado (1); traditional (3); user-deleted-1105 (1)
