Previous in Forum: Ferrite Core Power Handling Capacity   Next in Forum: 90° Supplies? Information Only.
40 comments
My Friend's 3 Cell Flashlight
01/01/2014 8:07 PM
My friend is a DYI guy. The bulb of his flashlight died just before New Year. He is living in Canada and the power will be off for maybe 1 more week. He found a bulb for 1.6 Volts and just put 1 battery in reversed into the tube of his flashlight.
What will happen with each of the batteries? Will they last longer, especially with the one in the middle that he placed the opposite way?
Re: My friends 3 cell flashlight
01/01/2014 8:33 PM
The reverse battery will have reverse current flowing into it at an unknown rate, not all 1.6 V light bulbs are the same. This could destroy the reverse battery or just make it overly warm. The two forward batteries will both discharge at the same rate as having just one battery connected to the light bulb. Have your DIY friend find a way to remove two batteries from the flashlight but still complete the circuit to the one remaining battery. Maybe a pipe could be cut to length or a wire strategically attached to a wood dowel could do the job.
Reply Good Answer (Score 4)
01/01/2014 8:47 PM
Will the battery be conserved, damaged or abused? Is the chemistry long lasting? Will it explode? He told me that the bulb is bright and the flashlight well performing. I will tell about your proposed solutions.
01/01/2014 8:53 PM
He's consuming two batteries at once for no benefit. Depending on the unknown reversed battery chemistry it could quickly fail it could just simply get warm.
01/01/2014 8:56 PM
Wow. Really?
Is the flashlight output brighter than his cellular phone screen? What happens when the phone gives up the ghost?
I would think proposals regarding no power for a week would be more welcomed than solutions to this supposed shiner problem.
01/01/2014 9:04 PM
" What happens when the phone gives up the ghost?" This discussion becomes moot.
01/01/2014 9:35 PM
You should know better than to question a problem posed by an anonymous poster. I believe this situation is a complete fabrication. How did the AP find out from his "friend" of the power loss; semaphore flags, smoke signals? What crystal ball determined this to be a week long outage? How will our TCIP encoded proposals to save batteries get to the AP's friend?
I agree with you, Doorman. If I was in the warmest province of Canada expecting a week in January without electric power, I would not waste cell phone power and bandwidth asking how to repair a flashlight. I certainly wouldn't argue with the advice I was given either. I might ignore the advice but not argue with it. Preventing plumbing and people from freezing would be my first two concerns.
01/03/2014 10:59 AM
Yeah. Tractor supply store is running a special on generators right now. I may go pick one up. Oh, BTW they operate on gasoline.
01/03/2014 9:06 AM
'or just make it overly warm'
That comment brings to mind Ohm's Law and a situation that happend when I changed some mercury cell's in a light and for a lack of a disposal place, dropped the expended cell's into my pocket....everything was fine until I added my keys and sat down.... the 'overly warm' cell created a quarter sized blister on the inside of my thigh and a slightly smaller blister on my scrotum. Not a good idea to reverse or short cells, not a good idea to put them in your pocket...
01/03/2014 9:51 AM
Thanks for sharing, it might would have been worse with fresh cells!!
01/03/2014 11:15 AM
Chestnuts roasting on an open fire..........
Reply Off Topic (Score 4)
01/01/2014 8:42 PM
This will depend on the wattage of the bulb and the capacity of the battery(s)....all things considered equal, the change from series to parallel configuration of the batteries should lower output and give less light but for a longer time....If the wattage of the light is higher, but the voltage lower, the results may be same amount of current draw....There is a finite amount of current available, whether configured in series or parallel, that does not change....
01/01/2014 8:54 PM
Ampoule is 1.7 V - and also 0.5 is printed on the screw and also 0 S RAM.
01/01/2014 9:11 PM
I would go with an LED superwhite for increased efficiency....
01/01/2014 9:40 PM
Can he get that delivered by drone?
01/01/2014 9:51 PM
That far north we use Owls...
Good Answers: 141
01/01/2014 9:21 PM
O s ram like Phil Lips?
Plenty of room here
Good Answers: 69
01/03/2014 3:04 PM
Regardless of the wattage of the bulb, there won't be any light output decrease if changing from the current (risky and very un efficient) configuration, to the one that you propose:
Right now the lamp is receiving its rated voltage; two cells in series ≈ 3V, minus one backwards ≈ 1.5.
Since all cells are in series and the load is at rated voltage, you are draining only the current that one single cell can deliver to such load, if you connect all of them in parallel, the load will still be at rated voltage.
However, a change in intensity (actually an increase) would be possible only if the bulb is rated at higher wattage than one single cell can produce, in that case, putting all of them in parallel, will rise a bit the light intensity, but the best part is that, as you said, the lamp will glow much longer.
If the lamp draws a current within the cell's capacity, the best solution is to cut a broom stick to the lenght of two cells, wrap it in Reylod's wrap, insert it in the flashlight and go using one cell at the time.
Re: My Friend's 3 Cell Flashlight
01/01/2014 8:52 PM
Put tape over the + contact of two batteries. Cover them completely with aluminum foil and put them back in the flashlight as spacers.
Actually, use two batteries to power the bulb and the other one as a spacer. More light that way.
I smell a rat here.
OS?
Reply Good Answer (Score 5)
Good Answers: 141
01/01/2014 9:15 PM
Lyn's solution is fast and easy to implement, considering you have the tape and alu foil.
Is your friend in the surveillance business?
The weight of the flashlight will remain the same in case he uses it again as a weapon. Is that how the bulb got busted?
Haven't these guys longer pipe flashlights?
He will also have 2 spare batteries on the go, without carrying them in his pockets.
G.A's have been limited for a while, but this one is well used.
Plenty of room here
Reply Off Topic (Score 6)
01/02/2014 9:59 AM
how nice of you to ask a question for "your friend", perhaps you should tell your friend of this forum do they can speak for themselves, that way it would save you time from relaying questions asked by us of "your friend"
01/02/2014 10:16 AM
Thank you for the answers.
Plenty good hints. For the suspicious ones. He has a generator, heard of it? And he is calling from his phone, that he charges in his car. Ever been without power? He thought reversing the battery was no problem. He did not ask me to contact you. That was my initiative. But actually nobody answered the real question. Very funny contributions.
01/02/2014 10:22 AM
Sorry, probably w're still a little celebrating maybe. Give your friend our regards. I think you should address your question to a battery manufacturer. There is a name on the battery, no? We just guess what happens. Our lab is closed during the holidays.
01/02/2014 10:23 AM
I knew it. You cannot recognize a "real" answer when you see one.
I also see from the two AP#1 replies that you are trying to play us.
Good Luck with your games.
Good Answers: 141
01/02/2014 10:36 AM
Obvious
Plenty of room here
Good Answers: 141
01/02/2014 10:31 AM
In my opinion nothing will happen with the battery, except that the chemistry inside will work in reverse at a less performance level. The electrodes will do their job in reverse and can handle the current.
The "electrolyte" will get exhausted and contaminated when the + is carbon composed.
I read, don't recharge, don't throw it in a fire but nothing about reversing the battery and dangers involved. The manufacturer however will sell more batteries, since you use the reverse one without getting anything out of it.
Also didn't read about accident reports.
Plenty of room here
Good Answers: 109
01/02/2014 4:24 PM
Maybe your friend should invest in a generator. Just tell him not to burn his car for warmth or he may be a victim of reverse Darwinism.
Good Answers: 54
01/03/2014 1:21 AM
There are many different scenarios:
1. All three batteries are the same type with the same charge.
2. Two batteries are alkaline and one is a regular heavy duty (zinc carbon).
3. One battery is alkaline and the other two are heavy duty.
4. Now we can throw in rechargeable batteries into the mix.
So, without knowing this, we're just guessing at the results. Also, it depends on the orientation of the batteries; alkaline = one forward, two forward, three forward, one backward, one forward and one backward, etc
More info coming?
01/03/2014 2:02 AM
He burnt a straight hole through the foil. Just where the little bump is on the +. All batteries are energizer, same model. Thick round cells. Had a great time. Doorman must have been burried a few years because he's still on a cell phone, or maybe in a phone cell? With a ghost, hope she's pretty. My friend is now "our" friend. He lives a few igloos away from me. We will push the button now together? A jolly good New Year to all.
Anonymous Poster #3
01/03/2014 3:41 PM
"burnt a straight hole through the foil"
Sounds like your friend has trouble with concepts and following instructions- the tape over the bump was for insulation, it needs to be thick enough to insulate. A cell with a low internal resistance might start a fire or explode. If it starts a fire use it to start the whale blubber lamp.
01/03/2014 3:50 PM
Good Post, true and funny!!!
My Friend Has This Problem...
01/03/2014 6:39 PM
Wow. Yeah, Doorman sticks with old tech, that's for sure...
Like having the correct replacement flashlight bulbs on hand.
See ya, I'm outta here.
Re: My Friend Has This Problem...
01/03/2014 6:50 PM
I think this dork lives in Colorado and is testing a new strain of gonja.
See ya in Jamaica next week at the board meeting Doorman.
01/03/2014 4:23 AM
The reversed battery will get damaged, how bad? Only he will be able to find out as I am sure that such tests are seldom made.
I personally would never do it as the outcome could be not quite what is needed. It demonstrates a certain lack of full knowledge on the side of the user.....if a house fire was caused, he would look pretty sick!!!
There are replacement bulbs with LEDs in them for multi-cell flashlights, they will work in 2 or 3 battery flashlights with no modifications according to the ads..
Here is one for use between 3-4.2 volts from ebay for example:-
High Power LED Replacement bulb
It will give a better light and also longer battery life.
Best of luck.
01/03/2014 4:32 AM
It will give a better light and also longer battery life. You only need to make sure that it has the right sort of case, or adapt it to fit quite easily.....
Best of luck.
Anonymous Poster #2
01/03/2014 4:34 AM
WHAT IS A "DYI GUY", someone dying to die? He gives that impression!!
01/03/2014 5:24 AM
Correct. DYI stands for Do Yourself In.
01/03/2014 5:49 AM
LOL!
OF COURSE!!
Thanks for the explanation!!!
01/03/2014 3:54 PM
Wrong finger control. Was supposed to be DIY. The suggestions point to just a matter of size (in or out?) My apologies for that.
Good Answers: 141
01/03/2014 9:18 PM
Interesting: is it now DYI or DIY?
http://www.urbandictionary.com/define.php?term=DYI
Plenty of room here
01/04/2014 11:38 AM
When signaling your distress to others, do not raise the middle finger of fate.
Reply to Forum Thread 40 comments
Andy Germany (5); Anonymous Poster (8); Autobroker (1); Doorman (2); dvmdsc (5); Fredski (1); geraldpaxton (1); James Stewart (2); kevinm (1); lyn (4); phph001 (1); redfred (4); SolarEagle (3); XNuke (1); Yahlasit (1)
