Previous in Forum: How to Justify Electrical Eqpm Area Classification Inside Gas Turbine Compressor   Next in Forum: Burnt Outlet
Thank Team
01/03/2014 2:39 PM
Thank team for ur contribution to my question-on generator low voltage. But later i realized the problem might hv come from The AVR,which i had to adjust.
Re: Thank Team
01/03/2014 6:32 PM
It's more appropriate to post replies in the thread to which they relate.
Re: Thank Team
01/04/2014 1:38 AM
http://cr4.globalspec.com/thread/87752#newcomments
Pl. refer my reply posting (given below) and the link is indicated above.
dhayanandhan
Re: Generator Output Voltage Low
01/03/2014 10:24 AM
Dear Mr.KWASI BIMPONG
First Read the User's Manual. You have not mentioned whether the Voltage is full before putting any load, and when load is put the voltages dips.?
I am assuming the Load is not put and the Possible Reasons for Low Output Voltage of Generator, will be as follows.
1. Prime Mover Speed is low.
2. Excitation Problem - no sufficeint field current is circulating.
3. Defective diodes if revolving diodes are used.
4. Defective AVR
5. Stator Winding might have partly opened etc. 5. No residual Magnetism
Pl. check with in CR4 and you will get plenty of information, as this topic came up some time back.
DHAYANANDHAN.S
Reply Report! Good Answer (Score 4)
Register to Reply 2 comments
